Extract items between FROM and WHERE
K
Hello,
I would like to get a list of tables listed in a SQL SELECT statement. I
have not figured out how to code it nicely.
Sample statement:
SELECT * FROM table1, table2 "alias2", table3 as "alias3" WHERE ...
I would like to see the result as:
table1
table2
table3
Thanks for your help,
ktmd
R
RichS
Try this
$sqlcmd = 'SELECT * FROM table1, table2 "alias2", table3 as "alias3" WHERE
## set to lower case
$sqlcmd = $sqlcmd.ToLower()
## drop the where and later
$i = $sqlcmd.Indexof("where")
$temp = $sqlcmd.substring(0,$i)
$temp = $temp.Replace("select * from ", "")
$array = $temp.split(",")
for ($i=0; $i -lt $array.count; $i++){
$array[$i] = $array[$i].Trim()
$j = -1
$j = $array[$i].Indexof(" ")
if ($j -ge 0){$array[$i] = $array[$i].substring(0,$j)}
$array[$i]
Richard Siddaway
Please note that all scripts are supplied "as is" and with no warranty
"ktmd" wrote:
> Hello,
> Sample statement:
> table1
> table2
> table3
> ktmd
V
Vasily Gusev
Another variant using Regex:
$sqlcmd -match "FROM(.+)WHERE" #this will crop all text between FROM and
WHERE to $matches[1]
$m = [regex]::Match($matches[1],"[ ,]([\w\d]+?)[, ]") # select all words
surrounded by spaces or colons (not quotes)
while ($m.groups[1].value){$m.groups[1].value; $m=$m.nextmatch()} #iterate
through all matches
May look more complicated if you not familiar with regular expressions.
"ktmd" <ktmd@discussions.microsoft.com> wrote in message
news:81C9286F-C962-45E1-BC17-C17A1BC26637@microsoft.com...
> Hello,
> Sample statement:
> table1
> table2
> table3
> ktmd
M
mikes.net
Careful. It is easy to forget to make sure you can search across
lines. On top of that, Powershell is very tricky with newlines. And
on top of that, sometimes `n is treated exactly as `r`n which is
treated exactly as [Environment]::Newline.
One way to make sure your searches can "wrap" is to join all the lines
after Powershell has finished chomping them and stuffing them
individually in an array, but before performing the regex: % {
[string]::join(" ",$_) } There are many other ways to do this, though
I yet to develop a fully satisfying one.
Mike
> through all matches
> "ktmd" <k...@discussions.microsoft.com> wrote in messagenews:81C9286F-C962-45E1-BC17-C17A1BC26637@microsoft.com...> Hello,
> > Sample statement:
> > table1
> > table2
> > table3
> > ktmd
K
Thanks everyone for the responses. My problem was solved.
It is good to see multiple techniques to solve the problem.
ktmd
> Mike
> > through all matches
> > > Sample statement:
> > > table1
> > > table2
> > > table3
> > > ktmd
