Failed installation
R
I have IBM X40 Laptop with additional External USB disk running winxp SP2
with IE7 beta 2.
I have tried to install vista beta 2 on the external disk and the following
happens:
1. Installation fail - When trying to boot the vista you get:
\windows\system32\winload.exe 0xc000000e
2. When you try to rollback installation you get error saying rollback
failed. A second attempt to rollback open command prompt in
x:\windows\system32 and nothing happens.
3. In my old winxp IE7 dispaly empty pages , uninstalling IE7 did not did
not change the situation.
This post is a suggestion for Microsoft, and Microsoft responds to the
suggestions with the most votes. To vote for this suggestion, click the "I
Agree" button in the message pane. If you do not see the button, follow this
link to open the suggestion in the Microsoft Web-based Newsreader and then
click "I Agree" in the message pane.
http://windowshelp.microsoft.com/co...osoft.public.windows.vista.installation_setup
J
Jane C
You cannot install Vista onto an external USB connected hard drive. It will
not boot from an external USB connected hard drive.
Jane, not plain ;) 64bit enabled ;)
Batteries not included. Braincell on vacation ;)
"RE66" <RE66@discussions.microsoft.com> wrote in message
news:B71FB903-FEBC-45E3-9696-DF703E7CE102@microsoft.com...
> with IE7 beta 2.
> following
> happens:
> this
D
droid
If you get Vista to work from USB HDD please let us know how :-)
So far I've only heard that it is not possible. If it did work it would
likely be very very slow.
> with IE7 beta 2.
> following
> happens:
> this
R
If it should not work why the installation process let you try...........
> > with IE7 beta 2.
> > following
> > happens:
> > this
R
So why the installation process let you choose external USB drive....
> > with IE7 beta 2.
> > following
> > happens:
> > this
=?Utf-8?B?c3cx?=
I get the same error and I'm using a desktop with an internal hd...any ideas?
> with IE7 beta 2.
> happens:
