Failed System Restore
B
Beemac
Using Vista Home Premium on Tosh Equium laptop & system restore fails -
message "unspecified erreor occurred". System operating OK - nil issues with
reduced speed. Any suggestions as to how overcome failed restores?
TBK White
N
Nonny
On Sun, 8 Jun 2008 11:52:01 -0700, Beemac
If the system is "operating OK", then why are you trying to run System
Restore?
M
Malke
> with reduced speed. Any suggestions as to how overcome failed restores?
Check here and see if anything looks like it fits your situation:
MVP Bert Kinney on System Restore - http://bertk.mvps.org/html/vista.html
Problems caused by Symantec - http://bertk.mvps.org/html/symantecdoc1.html
System Restore - Error Messages in Vista -
http://bertk.mvps.org/html/eerrormsgsv.html
Malke
MS-MVP
Elephant Boy Computers
www.elephantboycomputers.com
Don't Panic!
R
> fails - message "unspecified erreor occurred". System operating OK
> - nil issues with reduced speed. Any suggestions as to how
Boot to Safe Mode, then run system restore. On my system, that's the
only way that works. If I don't use safe mode, I always get the same
unhelpful error message.
Ray
(remove the Xs to reply)
