Fan Speed Control and Overclocking
Elite47
Is there any way to control the fan speeds on the system? I checked the bios but since my fans arn't stock (upgraded) they dont appear. No Vista option for the fan speeds either. I have downloaded various programs, SpeedFan ect, but none seem to make my runs run at 100% Its always ranging from 50% to 60%.
Also, are there any good programs to overclock the CPU? I'm having alot of trouble with my MSI Neo P45 motherboard. I've got the right components and all, but it wont let me overclock my QX6700 past 2.8 when it was 2.66. I want to at least get it to 3.44ghz.
    Intel QX6700 2.66GHz OC'ed
    MSI Neo P45
    4GB DDR2-800 OC'ed
    ATI 4850 HD 512mb OC'ed
    20" Widescreen LCD
    1680 x 1050
    320GB 7200rpm
    600W
    Nzxt Zero Full Tower
    11 Cooling fans
    T1
SIW2
Not sure what's going on with your fans are you sure they are supposed to run at 100% ? - are the correct options enabled in the Bios - worth checking the manual or get it from your mobo's website - also see if they have an updated Bios available.
CPUID has oc'ing functions - it warns you it's at your own risk, of course - they also do HWMonitor which should help you see what's going on with your fans and temps.
CPUID
Hope this does the trick
SIW2
    Intel E8400
    ASRock1333-GLAN R2.0
    2gb DDR2 800
    nvidia 9500GT 1gb
xguntherc
I Click Home To Much
CPUId has Oc'n fucntions. I've never known that. lol
Your fans should not be going at 100 percent. and you should for sure be able to OC that thing plenty far.. how far is your RAM Oc'd. Try setting Ram to unlinked. and set it at stock 800, then add a little voltage and crank that thing to 3.33 GHz. I'd try that first. just set the fsb to 1333. and you can probably make that on stock volts. I can hit 3.33 GHz on stock volts on my Q6700 no X edition. I run mine Daily at 3.66 GHz these days. used to be 3.5 but 3.66 GHz is my sweeeeet spot I'd decided. I've gotten it to 3.7 Ghz also.
What cooler do you have?
    Q9650 E0 4.0 GHz @1.304v
    eVGA 750i FTW
    eVGA/MSI GTX 260 SLI
    X-Fi XtremeGamer
    Samsung T240 & 226BW
    1920x1200 & 1680x1050
    PC P&C 750w Silencer PSU
    Logitech MX-518
    Logitech G11
