favourite links not creating shortcuts!
K
kateinsoll
I managed to delete my Links folder in my user profile. After some
googling I recreated it by typing "shell:links" in the run
command.
But now when I drag a file into the Favorite Links area of the
Navigation pane, it's copying the files instead of creating a
shortcut!
I can force it to create a shortcut by holding down the Alt key - but
this is painful. Is there anyway to get it back to how it used to be?
K
Keith Miller \(MVP\)
It needs its desktop.ini file. Copy the following (between the lines) into
notepad:
[.ShellClassInfo]
LocalizedResourceName=@%SystemRoot%\system32\shell32.dll,-21810
IconResource=%SystemRoot%\system32\imageres.dll,-185
DefaultDropEffect=4
[LocalizedFileNames]
Public.lnk=@shell32.dll,-21816
Searches.lnk=@shell32.dll,-9031
Recently Changed.lnk=@shell32.dll,-32813
Music.lnk=@shell32.dll,-21790
Pictures.lnk=@shell32.dll,-21779
Documents.lnk=@shell32.dll,-21770
and save in the 'Links' folder as 'desktop.ini'
Press & hold the <shift> key and right-click in the folder background &
select 'Open Command Window Here'. Then execute the following:
attrib +h +s desktop.ini
cd ..
attrib +r links
Setting the read-only attribute for the folder tells Explorer to process the
desktop.ini file.
Good Luck,
Keith
Microsoft MVP [Windows Shell/User]
<kateinsoll@xxxxxx> wrote in message
news:1b9d6ac7-0ca8-4262-897c-bc2dc383c854@xxxxxx
> command.
> shortcut!
