M
Maelmoro
Looking for a program to send fax from my Windows XP/Vista/Seven
through my modem. Can someone suggest one?
It seems like there isn't.. :O
Max
Max
> >It seems fax machines are becoming obsolete...
> I can't understand what you mean. I'd like to use the internal modem
> of my PC.. any suggest about a good program?
> Max
>3 OS you mentioned have fax software.
>> Any reason you don't want to use the Fax program supplied with your OS? All
> I can't find it on my XP and Vista.. where is it, please?
Maelmoro wrote:on XP Start -> Control Panel -> Add or Remove Programmes -> Add/Remove>
Windows Components -> Fax Services
Andrew Rinaldi
Mainpine Developer Support
USA +1 866 363 6680 | UK +44 1225 637 105
[email protected] | www.mainpine.com
