file defragmentation
G
Guest
Is it possible to run the Contig / PageDefrag tools in Vista?
Are they needed? Or does Vista defragment the files / pagefile in
background?
D
Dustin Harper
Defrag has a new look, but it runs by default every Wednesday at 1:00am.
You can also run it manually by going to Start Orb | All Programs |
Accessories | System Tools | Disk Defragment
Dustin Harper
dharper@vistarip.com
http://www.vistarip.com
<pasticka@bleble.jixo.cz> wrote in message
news:urh0TaHZHHA.1008@TK2MSFTNGP03.phx.gbl...
> background?
O
OKuma
The defrag tool in Vista is made by Diskeeper.
Basically, this defrag tool has been embedded in to the OS since Win95.
The built in tool, to my knowledge, does not defrag the pagefile or the MFT.
You would need to get a full version of a Defrag Software.
Just a note:
I believe Microsoft was made to remove the build-in Diskeeper from all
the Windows OSes that were to be used by German Government.
Diskeeper has version 2007, but you have to download a patch to get it to
work with Vista.
Also, the price depends on the version of Vista you are running. It can get
expensive.
I recently converted to PerfectDisk 8.0 by Raxco. They are the only defrag
software that is certified to run on Vista.
It's a lot faster and does a much better job than DiskKeeper.
But anyway, to defrag the Pagefile and or the MFT, you will need a Third
Party Defrag Tool.
As long as the pagefile is not managed by the system, you shouldn't get much
fragmentation, but the MFT on the other hand, gets heavily fragmented.
Personally, I would get PerfectDisk 8.0, it's doesn't cost a whole lot, it's
$8 for a year of maintained, and it's the only defrager the is Certified to
Run on Vista.
Just my .02¢
Regards,
OKuma
> background?
D
Duncan McC
In article <0A49108C-8BB6-4D7A-BBEA-0B274C80903C@microsoft.com>,
okuma@okumaware.com says...
> Just a note:
> work with Vista.
> expensive.
> Party Defrag Tool.
> Run on Vista.
> Just my .02¢
Good info.
Have you tried the SysInternals defrag util - it defrags stuff that MS's
defrag doesn't. And it's free.
MS liked them so much, they bought em!
http://www.sysinternals.com
Chit! - just went there and it redirects to MS. And guess what, the
defrag tool isn't there!
Seems to be the only one missing - thanks Microsoft.
Duncan
D
Duncan McC
> Just a note:
> work with Vista.
> expensive.
> Party Defrag Tool.
> Run on Vista.
> Just my .02¢
OK - I'm wrong :)
Here tis:
http://www.microsoft.com/technet/sysinternals/utilities/pagedefrag.mspx
Don't know if it works on Vista.
Duncan
G
Guest
In Win 95 Norton supplied the defrag. In Win2000 and later NT systems
diskkeeper did provide the defragger. Vista's does do the MFT although XP's
didn't.
"Duncan McC" <hard@work.ok> wrote in message
news:MPG.2067e40a4ecc8c98988a@news.microsoft.com...
>> MFT.
>> Just a note:
>> all
>> work with Vista.
>> get
>> expensive.
>> defrag
>> Party Defrag Tool.
>> much
>> it's
>> to
>> Run on Vista.
>> Just my .02¢
> Good info.
> Duncan
