Solved file folder stuck in recycle bin
scw
4
hey guys,
im new to this fourm and not sure if this topic has already been posted, too lazy to check...
ive had a file folder stuck in my recycle bin for a couple of weeks now. the folder contained some audio files. if i try to empty the recycle bin, it goes through the normal processes i.e. "are you sure..." when i click yes it makes the sound that it usually makes of crumbling paper but the icon is still full and the folder is still there. also if there is anything else in the bin and i try to empty it it will do the same thing as i just described but everything stays in the bin. therefore i have to go through and permanently delete every thing individually. ive tried permanentlydeleteing the particular folder in question and it is not working.
any advice would be much appreciated
thanks a lot
Shadowjk
Network Enthusiast
2,180
Location
Northamptonshire, England
    Intel Core i5 2400 @ 3.10GHz
    Foxconn H67MP-S/-V/H67MP
    8.0GB DDR3 @ 665MHz (2GBx4)
    AMD HD Radeon 6870
    SMB1930NW (1440x900@60Hz)
    Novatech Night
    Dell HID-compliant mouse
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
Shadowjk
Network Enthusiast
2,180
Location
    AMD HD Radeon 6870
    Novatech Night
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
ive done the disk clean up as well as all of the options from the corrupted recycle bin link and still no luck
SCW,
Did you use the corrupted tutorial on all of your hard drive's $Recycle.bin folder for each drive letter?
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
scw
4
i failed to mention, i cannot seem to find the $recycle.bin folder. ive enabled the showing of hidden folders and it is not where it is supposed to be.
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
#8
Ah, I see. You will need to do both of these in Folder Options before you will see it.
A) Dot Show hidden files and folders.
B) Uncheck Hide protected operating system files
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
#10
You're most welcome SCW. I'm happy to hear that you got it sorted and that we were able to help. :)
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
Shadowjk
Network Enthusiast
2,180
Location
#11
Well done on Getting it sorted :) Brink Is awesome
    AMD HD Radeon 6870
    Novatech Night
