File Trnafer issue
M
mohieb
dear all,
is there a way to disable file tranfer on windows live messenger i tried the
registery but it doesn't work
S
Susie
On windows live tool bar.. Try tools, options, select file transfer on the
left and ... and then check Automatically reject file transfers .. Have you
tried that ? Hope it works :) good luck
"mohieb" wrote:
> dear all,
J
Jonathan Kay [MVP]
Greetings,
There are no specific settings for this I'm afraid.
The old registry options you can google up are for Windows Messenger, not Windows Live
Messenger and will not work.
Jonathan Kay
Microsoft MVP - Windows Live Messenger
MSN Messenger/Windows Messenger
MessengerGeek Blog: http://www.messengergeek.com
Messenger Resources: http://messenger.jonathankay.com
(c) 2008 Jonathan Kay - If redistributing, you must include this signature or citation
"mohieb" <mohieb@xxxxxx> wrote in message
news:8F955137-0782-43FD-98D0-CD1699CAF7C4@xxxxxx
> dear all,
