files are read only when extracted from Zip folders
J
Jeannette
Hello,
Whenever I extract a file from a zip folder or from a zip file from the
network, the file is set to 'read only'. That's annoying. Any way to change
that?
Thanks
Jeannette
R
Rick Rogers
Hi Jeannette,
All folders appear "read only", this attribute only applies to files. The
appearance of that attribute in a folder's properties is misleading.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
"Jeannette" <Jeannette@discussions.microsoft.com> wrote in message
news:870BF9A9-8E41-47F9-A83E-8FBC93C2F6F7@microsoft.com...
> Hello,
> change
> that?
> Thanks
> Jeannette
J
Jeannette
So how is it that when I try to open the file my program warns me that it is
read only and that after I change the properties it opens ok?.
I solved the problem. I installed my old trusty PKzip Explorer that I was
using in W2k and that works fine.
Thank you
Jeannette
"Rick Rogers" wrote:
> Hi Jeannette,
> Best of Luck,
> > Hello,
> > change
> > that?
> > Thanks
> > Jeannette
