Find/Replace
  • Thread starter eric.eickhoff@sbcglobal.net
  • Start date
E
Hello,
I am just learning PowerShell and need a little guidance.
What I am trying to do is to search a directory recursively for files
that contain a text string and modify the file(s) by replacing that
string with other text.
To do the search, I can use:
dir -r c:\temp\* | Select-string "xyz"
but from there, I am not sure how to go about doing the replace in
each file found.
Can anyone point me in the right direction to accomplish this?
Thanks,
-e
K
Keith Hill
<eric.eickhoff@sbcglobal.net> wrote in message news:1174589436.498853.183440@n76g2000hsh.googlegroups.com...
> Hello,
> each file found.
There isn't a native PowerShell cmdlet that replaces strings in files in place. However there is a -replace operator that provides the basic replace functionality. You will need to do this in several steps:
$pattern = 'some search pattern - could be regex'
$replacement = 'some replacement potentially using capture groups like so $1 $2 or ${namedGroup}'
foreach ($file in (gci c:\temp\* -rec)) {
$text = get-content $file
if ($text -match $pattern) {
$text -replace $pattern, $replacement > $file
Keith
D
Duncan Smith
That looks interesting, I was still thinking of a solution using the
Win32 Unix tools find, egrep and sed, bur their sed implementation
didn't update files in place so it all fell a bit flat..
I'm a little puzzled by where -match and -replace come from, as they
are not native to powershell and do not appear to be members of the
string class either. Do they belong to an object - I can't find the
documentation in MSDN 2005?
Thanks,
Duncan.
O
/\/\o\/\/ [MVP]
they asre native powershell operators, for more information see :
Get-Help about_operator
Greetings /\/\o\/\/
> Thanks,
> Duncan.
D
Duncan Smith
On Mar 23, 11:57 am, /\/\o\/\/ [MVP] <o...@discussions.microsoft.com>
> Greetings /\/\o\/\/
> > Thanks,
> > Duncan.
Thanks ;-)
A
aaronlerch@gmail.com
On Mar 22, 11:52 pm, "Keith Hill" <r_keith_h...@mailhot.nospamIdotcom>
wrote:
> <eric.eickh...@sbcglobal.net> wrote in messagenews:1174589436.498853.183440@n76g2000hsh.googlegroups.com...
> > Hello,
> > each file found.
> Keith
Thanks Keith!
I think this function takes what you wrote and expresses it in an easy
to reuse way (if not a little harder to read):
function Replace-String($find, $replace, $includes)
get-childitem $includes | select-string $find -list |% { (get-
content $_.Path) |% { $_ -replace $find, $replace } | set-content
$_.Path }
http://www.aaronlerch.com/blog/2007/03/powershell-replace-string-function.html
