finding a word on a webpage
I frequently used this before but how in the world do you do it using vista?
On xp it was click on edit I think and you used a find feature.
D
I personally hold down control and press ''f'' (no quotations) to bring this
option up.
D
Dave Cox
=?Utf-8?B?cm9u?= <ron@xxxxxx> wrote in
news:94EF3FB2-842C-4966-BD94-1142C95E04DF@xxxxxx:
> using vista? On xp it was click on edit I think and you used a
> find feature.
just press f3
A
Andrew Murray
You search the web page in your web browser, using its Search/Find feature.
In Firefox, for example, it's Edit > Find on this Page. Isn't that the
sort of thing you're after?
It's not really a Vista issue - and most if not all browsers would have a
"Find" feature of some sort.
"ron" <ron@xxxxxx> wrote in message
>vista?
C
Charles W Davis
>vista?
Ctrl+F will open a find function in the following browsers:
IE7
Firefox 2
Netscape 9
Opera 9.27
Avant 11.6
Flock 1.1
Safari 3.1
And probably all of the other upteen browsers that exist. I only use the
ones listed.
B
Bender
If you press, then let go of the 'alt' key, the menu will show up, using
IE7.
> vista?
