Fixboot command needed
J
Joe727
Hi - what is the command prompt to repair the master boot record in Vista
5384? In XP it's fixboot and fixmbr.
I am running a triple boot PC. 98SE, XP Pro SP2 and Vista Beta 5384.
Thanks
Joe
C
Colin Barnhorst
It doesn't work that way in Vista. If you boot with the dvd you should see
some links in the lower left of the first screen. One of them offeres the
repair options.
"Joe727" <nospam@nospam.nospam> wrote in message
news:%23HHM539mGHA.4216@TK2MSFTNGP04.phx.gbl...
> Thanks
> Joe
J
Joe727
Tried those repair options, and they accomplished nothing. As far as I can
tell, there is not one specifically to repair the boot loader.
Any other thoughts?
Thanks
Joe
"Colin Barnhorst" <colinbarharst(remove)@msn.com> wrote in message
news:%23anDO79mGHA.2312@TK2MSFTNGP03.phx.gbl...
> see some links in the lower left of the first screen. One of them offeres
> the repair options.
>> Thanks
>> Joe
C
Colin Barnhorst
Then you need to use BCDedit. It is not intuitive. You may also use
VistaBootPro which does have a graphical front end.
http://www.vistabootpro.org/intro.php
news:uC1gvp%23mGHA.192@TK2MSFTNGP03.phx.gbl...
> can tell, there is not one specifically to repair the boot loader.
> Any other thoughts?
> Thanks
> Joe
>> offeres the repair options.
>>> Vista 5384? In XP it's fixboot and fixmbr.
>>> Thanks
>>> Joe
J
Joe727
I have VistaBootPro - the question is, how do I boot to Vista if it doesn't
appear on my selection screen at boot up?
It's the same wth BCDedit. It only works in Vista as far as I know.
Joe
news:uQ5tcA$mGHA.2264@TK2MSFTNGP04.phx.gbl...
>> Any other thoughts?
>> Thanks
>> Joe
>>>> Thanks
>>>> Joe
C
Colin Barnhorst
Not true. It works fine from XP.
news:OaUqbI$mGHA.2252@TK2MSFTNGP04.phx.gbl...
> Joe
>>> Any other thoughts?
>>> Thanks
>>> Joe
>>>>> Thanks
>>>>> Joe
G
Georges Jullien
"Joe727" <nospam@nospam.nospam> wrote in:
> Thanks
> Joe
You can use bootrec /fixboot or bootrec /fixmbr in the "command prompt" of
the DVD :
Boot on the Vista DVD. Choose country. Next. Choose keyboard. Next.
Don't choose "install now" but "system recovery options" . If it is proposed
to repair at the end of the search, answer "no". Deselect all lines and clic
"next"
Choose "command prompt"
Type bootrec /? to access the bootrec help
A usefull command is also :
bootrec /rebuildbcd
Yours sincerely
Georges Jullien
C
Chad Harris
#8
Re: Fixboot command needed Which Sys Rec Options did you try?
Joe--Precisely what did you try? I'm hearing "tried those options" the same
way I have heard for 7 years "tried Safe Mode in XP: when people have in
fact tried one Safe mode option instead of the four they should try since
one may work. Did you try all 3 options 1) Startup Repair and 2) System
Restore after clicking into System Recovery Options from setup?
CH
> Any other thoughts?
> Thanks
> Joe
>>> Thanks
>>> Joe
J
Joe727
#9
There are five repair options IIRC, on the Vista repair screen. I don't
remember all the names. I am talking about booting to Vista, not XP.
I tried all of them, including System Restore, which did not work.
Joe
"Chad Harris" <Bushisamoron.net> wrote in message
news:%23C4pfrBnGHA.4672@TK2MSFTNGP02.phx.gbl...
> same way I have heard for 7 years "tried Safe Mode in XP: when people
> have in fact tried one Safe mode option instead of the four they should
> try since one may work. Did you try all 3 options 1) Startup Repair and
> 2) System Restore after clicking into System Recovery Options from setup?
> CH
>> Any other thoughts?
>> Thanks
>> Joe
>>>> Thanks
>>>> Joe
J
Joe727
#10
OIC - thanks for that info.
Joe
news:OkQFCL$mGHA.4636@TK2MSFTNGP03.phx.gbl...
>>doesn't appear on my selection screen at boot up?
>> Joe
>>>> Any other thoughts?
>>>> Thanks
>>>> Joe
>>>>> should see some links in the lower left of the first screen. One of
>>>>> them offeres the repair options.
>>>>>> Thanks
>>>>>> Joe
J
Joe727
#11
"Georges Jullien" <nospamgrjullien@numericable.fr> wrote in message
news:O4kFZaBnGHA.2244@TK2MSFTNGP02.phx.gbl...
>> Thanks
>> Joe
> the DVD :
> proposed to repair at the end of the search, answer "no". Deselect all
> lines and clic "next"
> bootrec /rebuildbcd
> Yours sincerely
> Georges Jullien
Thanks for the information. However, for some unknown reason, the System
Recovery Options interface is reporting that my Vista installation is on
partition J instead of partition N. Drive J is actually on my second hard
drive.
98SE is on partition E drive 1 / XP Pro on partition F drive 1 / Vista on
partition N drive 1 / Boot Loaders on Partition C drive 1 which of course is
the Windows default. F & N are NTFS. C & E are FAT32.
I ran the bootrec /rebuildbcd and the bootrec /fixboot, but neither worked.
In fact, I had to install the XP Retail CD and use the Recovery Console to
run fixboot in order to boot into XP.
Any other suggestions other than reinstall Vista?
Joe
J
Joe727
#12
Update - VistaBootPro doesn't repair the boot loader. Their website says
that funtion will be in their next release.
I couldn't get BCDedit or BCDedit.exe to work in a command prompt in XP Pro.
Joe
news:%23UB4mJDnGHA.692@TK2MSFTNGP04.phx.gbl...
> Joe
>>> Joe
>>>>> I can tell, there is not one specifically to repair the boot loader.
>>>>> Any other thoughts?
>>>>> Thanks
>>>>> Joe
>>>>>>> 5384.
>>>>>>> Thanks
>>>>>>> Joe
M
MICHAEL
#13
"Joe727" <nospam@nospam.nospam> wrote in message news:ukIb6IDnGHA.816@TK2MSFTNGP05.phx.gbl...
Hey, Joe. Not sure if this would help you, shouldn't hurt.
I ran Acronis from XP after Vista's install to give
Vista more space. I ended up not being able to boot
to Vista. "Couldn't find winload.exe" was the error. I
tried this, it worked.
Accessing bootsect.exe from
the DVD via XP, I ran the cmd "d:\boot\bootsect /nt60 F:"
"F" being my Vista volume as seen by XP.
-Michael
H
halfspeed
#14
As a last resort boot to the Windows 98 boot disk (floppy)
choose no cdrom support and at the command prompt A: type in fdisk/mbr
this should restore the mbr. This has saved my skin many times over.
news:OvYv8cDnGHA.5056@TK2MSFTNGP04.phx.gbl...
>>> Thanks
>>> Joe
>> of the DVD :
>> bootrec /rebuildbcd
>> Yours sincerely
>> Georges Jullien
> drive.
> is the Windows default. F & N are NTFS. C & E are FAT32.
> worked. In fact, I had to install the XP Retail CD and use the Recovery
> Console to run fixboot in order to boot into XP.
> Joe
J
Joe727
#15
"MICHAEL" <u158627_emr@dslr.net> wrote in message
news:uL1vo4EnGHA.1208@TK2MSFTNGP04.phx.gbl...
> to Vista. "Couldn't find winload.exe" was the error. I tried this, it
> worked.
> -Michael
Hi Michael - thanks for posting. I had to make an assumption about your
drive/partition letters. I assume D is your DVD drive and F is where Vista
is installed.
L is my DVD drive and N is where Vista is installed. F is where XP is
installed.
I ran L:\boot\bootsect /nt60 N: - I got a confirmation that the boot was
fixed but the Vista boot loader did not appear on reboot.
Joe
M
MICHAEL
#16
"Joe727" <nospam@nospam.nospam> wrote in message news:uWAfdDFnGHA.4532@TK2MSFTNGP02.phx.gbl...
>> worked.
>> -Michael
> is installed.
> installed.
Your assumptions were correct. Sorry it didn't work.
Hope you figure it out.
Take care,
Michael
J
Joe727
#17
news:OHEQIYFnGHA.3656@TK2MSFTNGP03.phx.gbl...
>>>> don't remember all the names. I am talking about booting to Vista, not
>>>> XP.
>>> worked.
>>> -Michael
>> Vista is installed.
>> installed.
> Take care,
> Michael
Ok - thanks again.
Joe
M
Michael Cecil
#18
You could always image your existing Vista drive to somewhere safe, boot
from the Vista disc and install Vista to get the booting fixed, then
restore just the Vista image without changing the boot drive.
Michael Cecil
http://home.comcast.net/~macecil/
http://home.comcast.net/~safehex/
J
Joe727
#19
"Michael Cecil" <macecil@comcast.net> wrote in message
news:huhaa2dqhrpb2ru6f0o3ske0k5b5jaf1bi@4ax.com...
> Michael Cecil
It's not a big deal. I can reinstall Vista. I am just checking it out
along with the new Office Suite Beta. Vista is very nice, but I sure miss
the little Cat helper in Office. I use the Cat instead of Clippy.
Joe
C
Chad Harris
#20
You should definitely move up from the cat to a dog. Your life with
computers would get much better. I can also show you how to hack the dog
that is used as the search helper to make it have diverse sounds and do a
gamut of tricks so you can begin focusing on the priorities in life.
CH
news:%23m1n0lGnGHA.4500@TK2MSFTNGP03.phx.gbl...
>> Michael Cecil
> Joe
