Fixed to expanding hard drive or add another hard drive?
M
Melelina
I have Vista Ultimate on VPC and one fixed virtual hard drive. I am out of
space on that drive. I would appreciate pros and cons on whether I should
convert the fixed drive to an dynamic expanding one or should I add a second
virtual disk and if I do that does it need to be fixed like the current one?
P
philo
"Melelina" <melelina@xxxxxx> wrote in message
news:eSTS8CCkJHA.1388@xxxxxx
>second virtual disk and if I do that does it need to be fixed like the
>current one?
I'd use the dynamic expanding option
and simply set the size for the maximum you think you may eventually need.
No harm in making your estimate on the high side...as it will only expand to
what is actually needed.
M
Melelina
"philo" <philo@xxxxxx> wrote in message
news:OQjGiEQkJHA.3380@xxxxxx
>>current one?
> to what is actually needed.
The Help file is sort of confusing on this:
Hmmm....I can't copy/past from the help file. I wonder why? Anyhow, the
help file says that before converting to an expanding disk, I need to use a
third party disk utility to zero out the blank spaces. I don't know what
that means. Then it says that after I do this, I need to compact the disk.
This is while it is still a fixed size disk.
Then the Help file appears to contradict itself when I look at the Compact a
virtual Hard Disk section. There it says that the compaction option is
available ONLY for expanding disks. Huh? Earlier it says under Create a
Dynamically Expanding Disk from a Fixed Size disk that I am supposed to
compact the disk after using a third party software to zero out the blank
spaces and it says I am supposed to compact the disk while it is still a
fixed disk BEFORE converting it.
That is all very confusing. Plus, I don't know what zeroing out blank spaces
means.
B
Bo Berglund
On Tue, 17 Feb 2009 03:40:50 -1000, "Melelina" <melelina@xxxxxx>
>>>current one?
>means.
In your case I'd do one of two things:
1) Use VHDResizer to move your old vhd disk data into a new fresh
dynamically expanding disk set to a really large size.
At the end you need to expand the new VHD partition (because it will
be a same-sized partition plus lots of unused space). You can do this
according to a description in this link:
http://kb.dutchalps.com/microsoftvirtualpc.htm
2) Create a new empty virtual disk using the virtual disk wizard.
Then attach this to the guest you want to expand the disk of.
Then boot up the guest and use whatever disk imaging software you have
access to to copy your boot disk image to the now available new and
empty disk. I have done this using both Norton Ghost 2003 and Acronis
Workstation products. Ghost 2003 works well for operating systems
below Vista, but has trouble with Vista. Acronis handles Vista too
just fine.
These products will allow expanding the data into the full disk sized
partition at imaging time so after you are done, just shut down the
guest and in the guest settings change the virtual disks (disable disk
#2 and set the new disk as disk #1)
DONE
Bo Berglund (Sweden)
S
Steve Jain [MVP]
On Mon, 16 Feb 2009 00:24:20 -1000, "Melelina" <melelina@xxxxxx>
Simply converting to a dynamically expanding drive isn't going to
help. You've already set the maximum size of the disk. A dynamically
expanding disk only expands to it's maximum size.
Example: if your fixed disk is 20GB, converting it to a dyn disk will
simply make it a dyn disk with a 20GB expansion limit.
Cheers,
Steve Jain, Virtual Machine MVP
http://vpc.essjae.com/
M
Melelina
"Bo Berglund" <boberglund@xxxxxx> wrote in message
news:s9plp4lfadhce9ds7mmj3vl4ij5ngp435h@xxxxxx
>>>>of
>>>>should
>>>>current one?
>>> need.
>>> expand
>>a
>>a
>>spaces
>>means.
> just fine.
> DONE
I have Seagate's version of Acronis TI 10 so I think it could do this (I
think the only thing it lacks the ability to do incremental images). But I
will look into your first suggestion also. Thank you.
M
Melelina
"Steve Jain [MVP]" <noreply.-@-.essjae.com> wrote in message
news:gr2mp4hf4pcrei9itqu857tqbqnu4pq778@xxxxxx
>>second
>>one?
I didn't realize that. Why does VPC use an expanding disk by default then?
VMWare Workstation tells you to do a fixed disk rather than dynamic. But I
thought that on both softwares that dynamic would expand without any limit.
I sure have been confused about that!
So, wouldn't the easiest thing be to just add another virtual drive?
> Cheers,
M
Mark Rae [MVP]
#8
news:%23a5ugcbkJHA.4696@xxxxxx
So as not to take up any more hard disk space on the host than is necessary.
Creating a 60GB fixed hard disk will create a 60GB vhd on the host
straightaway.
Creating a 60GB dynamic hard disk will not create a 60GB vhd on the host,
but it will create a vhd on the host which has the capacity to grow up to
60GB - when it's first created, it will only take up about 3K on the host.
Mark Rae
ASP.NET MVP
http://www.markrae.net
