BeardedBird
I just bought a brand new SanDisk 16GB Cruzer Glide USB Flash Drive. When I plugged it in, it loaded the drivers. When I clicked on it to use it, a warning came up that it needed to be formatted. I clicked Format Disk.
The defaut fields were: Capacity: 64.0MB - File System: FAT - Allocation Size: 1024 bytes.
I click Start, the green bar goes almost all the way across, then stops and a warning box comes up that says: Windows was unable to complete the format.
I cannot put anything on it without formatting it. Seems like nothing can be easy anymore.
Is there a solution that I can do or should I take it back to the store (faulty?) and try another?
Thanks.
P.S. - Keep suggestions simple please. Not that computer savy.
Thanks.
- Compaq Presario Model SR5223WM-B
- 120 GB ??
- Asus M2N68-LA / lvy8-GL6
- 1 GB 240 pin, DDR2 SDRAM / Added PNY 2GB DDR2
- Graphics Card(s)
- NVIDIA GeForce 6150 SE nForce 430
- HD 6-channel ALC 888 chipset
- Compaq W17q
