Flight Simulator 2004
flynryan692
Hey there, so I was having problem before where FS would freeze and the sound would make a loop sort of sound. I remember doing a bunch of searching around and I found a way so that when I click the fs9.exe vista would switch the theme from aero to basic until I closed FS. That solved everything. Well I reformatted and I can't figure out how I did that nor can I find the link to how to do that...does anybody know?
fieseler
Right click your application, in this case fs9.exe, and go to properties.
Then switch to the compatability tab and check "disable desktop composition"
Click apply, then click ok
job done.
    §ĮŁΣNŦ Д$$Д$$ĮN
    Xeon X3360
    P5W64 WS Pro
    EVGA Geforce GTX470 SC+
    Samsung T200
    WD 1TB RE3
    Thermaltake Toughower 750w
    NZXT Lexa Silver
    Zalman CNPS10x Extreme
    Razer Deathadder 3500dpi
    Razer Lycosa Mirror
    24Mb/s
