Flightsimulator X not compatible to Vista-aero?
A
armin
when I start FSX, the message 'colorscheme changed to vista-basic' appears,
cause the program ist not compatible with certain visual elements in vista.
Is FSX not compatible to Vista?
my system:
Vista Ultimate
AMD Athlon X2 4200
ATI X1900XT
2 GB RAM
Thanks for any suggestion
D
Dustin Harper
It is compatible with Vista, it just has to disable Aero to run correctly.
It re-enables it (or it should) when the game is stopped.
Dustin Harper
[email protected]
http://www.vistarip.com
"armin" <[email protected]> wrote in message
news:[email protected]
> appears,
> vista.
> my system:
> Vista Ultimate
> AMD Athlon X2 4200
> ATI X1900XT
> 2 GB RAM
A
armin
Thanks for the answer.
When it just has to disable Aero to run correctly, I know that I don't have
a miss-configuration.
> Dustin Harper
> [email protected]
> > appears,
> > vista.
> > my system:
> > Vista Ultimate
> > AMD Athlon X2 4200
> > ATI X1900XT
> > 2 GB RAM
R
Richard Urban
Aero uses a lot of video resources. FSX releases those resources so the can
be used by FSX, a very resource hungry game.
Regards,
Richard Urban MVP
Microsoft Windows Shell/User
> have
>> correctly.
>> Dustin Harper
>> [email protected]
>> > appears,
>> > vista.
>> > my system:
>> > Vista Ultimate
>> > AMD Athlon X2 4200
>> > ATI X1900XT
>> > 2 GB RAM
Yaz
Hi, i have the same problem except its worse... My fsx used to work fine then i get that same message about the aero color scheme being changed... So i tried everything like virus scan, cleaners..My problem: when i play FSX i can see the aircraft and use it like normal, But the aprons(grass between runways & taxiways) and also everything EXCEPT the aircraft, runways and taxiways, terminal, and sky is BLACK and sometimes changes colors of the spectrum.. Like rainbowish and back to black... Basically can't see the terrain and can't see the water...its either black or that altering rainbowing colors.. HELP is greatly appreciated.. Thanks
Timmah
Banned
I'd say try updating your graphics drivers. Then try running Windows Update, and also I find sometimes with issues like this may be caused by a buildup of static on the mainboard, so try unplugged all power sources and holding down the power button for 90 seconds ( Short the switch and drain the charge from the caps ) Then try the game again. I'd like to know if this works. Thanks.
    Self-Built
    AMD PHENOM X4 9600 BE 2.3GHZ @ 2.46GHZ
    TA790GX 128M AM2+
    8GB OCZ PC6400 800MHZ DDR2 RAM
    NVIDIA GTS 250 1GB VRAM
    SB5120 24-BIT 7.1
    AOC 2330V 23" LCD
    1920x1080
    250GB SEAGATE HDD
    650W
    GENERIC
    3 120MM FANS
    MS WIRELESS DESKTOP 3000
    6MB/s
    Main Machine. Just upgraded my RAM to 8GB. Next task will be to get a new processor for this machine ( 9650 was for my secondary machine )
