Font size for selected programs
228
Location
Potomac, MD
Is there a way to change the font size on selected programs?
I already have my font set at custom scale 144 DPI.
Two programs that I use have extremely small font for my senior eyes.
Secunia PSI and AVG PC Tuneup. Ctrl + - and Ctrl mouse wheel do not change the font on these programs.
If I increase the font above 144 it will be too large for other applications.
Thanks
Frank C
Yard Dog
2,169
Location
Central Florida in a small town
Hello, i found a couple of things for you, one is a hotkey that you have to set up . Look at this : ScreenMagnifier
Then , if that is not good for you, i have another idea . Maybe a screen attachment to use , magnifier. These cost money, and i do not endorse the products and do not want to appear to be spamming . but, i did google that and saw several that might work. Just a thought.
I almost forgot. In windows , start, accessories, in the ease of access, is a magnifier program built in. check it out, i find this the easiest way.
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
