Fonts - Change Default
How to Change the Default Vista Fonts
This will show you how to change most or all of the default fonts in Windows Vista for Active Title Bar, Icon, Inactive Title Bar, Menu, Message Box, Palette Title, Selected Items, ToolTip, and various Dialog Box text and buttons.
The Fonts folder is located at:C:\Windows\Fonts to see a list of available fonts that you can use below.
OPTION ONE
Through Advanced Appearance Settings
NOTE: This will let you change the default font, font size, and font color for the Active Title Bar, Icon, Inactive Title Bar, Menu, Message Box, Palette Title, Selected Items, and ToolTip text.
1. Open the Advanced Appearance settings window.​
2. Click on the Item: you want to change the Font for. (See screenshot below)​
NOTE: These are the Items that have fonts that can be changed. Repeat this for each item you want to change the font for. The font settings that are grayed out are not available with the selected color scheme.
  • Active Title Bar
  • Icon
  • Inactive Title Bar
  • Menu
  • Message Box
  • Palette Title
  • Selected Items
  • ToolTip
3. To Change the Item Font -
A) Click on the Font: drop down menu and select a font. (See screenshot below)​
4. To Change the Item Font Size -
A) Click on the Size: drop down menu and select a number for the size. The higher the number, the larger the size.​
5. To Change the Item Font Color -
A) Click on the Color: drop down menu and select a color.​
6. To Have the Item Font in Bold -
A) Click the B button to highlight it. If it is not highlighted, then the font will not be in bold.​
7. To Have the Item Font in Italic -
A) Click on the I button to highlight it. If it is not highlighted, then the font will not be in italic.​
8. Click on OK.​
9. Click on OK to apply changes.​
OPTION TWO
Dialog Box Text and Buttons
NOTE: This will let you change the default fonts for most of the Windows 7 dialog box text and button text through the registry.
1. Open the Start Menu.​
4. In regedit, go to: (See screenshots below step 5)​
Code:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\FontSubstitutes
5. In the right pane, right click on MS Shell Dlg and click on Modify.​
NOTE: The default fonts are the ones displayed below.​
6. Type in the name of the font you want to use and click on OK. (See screenshot below)​
NOTE: You can get the name of the font from the Font Folder Location C:\Windows\Fonts. Be sure that you use the exact same font name and that it is spelled correctly.
7. In the right pane, right click on MS Shell Dlg 2 and click on Modify.​
8. Type in the name of the font you want to use and click on OK. (See screenshot below)​
8. Close regedit.​
9. Log off and log on, or restart the computer to apply the changes.​
OPTION THREE
Change All Default Fonts
NOTE: This will let you change the default fonts used by Vista using the registry.
1. To Change Default Fonts Using a REG File Download
NOTE: This changes the default fonts in Vista to the Tahoma font. You could use this REG file download to make doing step 2 below easier by editing the REG file for the font you want to use instead of Tahoma.​
A) Click on the Download button below, and download the file below.​
Set_Tahoma_Default_Font.reg
download
B) Click on Save, and save the .reg file to the desktop.​
C) Right click the downloaded .reg file and click on Merge.​
D) Click on Run, Yes, Yes, and OK when prompted.​
E) Log off and log on, or restart the computer to apply changes.​
F) When done, you can delete the downloaded .reg file if you like.​
2. To Manually Change Default Fonts by Creating a REG File
NOTE: The REG file in step 1 is the same as in step 2B below. You can use it and just edit the font that you would like to use instead of Tahoma in step below.​
A) Open Notepad.​
B) Copy and Paste the code below into Notepad.​
Code:
[/INDENT][/INDENT]
[INDENT][INDENT]Windows Registry Editor Version 5.00[/INDENT][/INDENT]
[INDENT][INDENT][/INDENT][/INDENT]
[INDENT][INDENT][HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Fonts][/INDENT][/INDENT]
[INDENT][INDENT]"Segoe UI (TrueType)"=""[/INDENT][/INDENT]
[INDENT][INDENT]"Segoe UI Bold (TrueType)"=""[/INDENT][/INDENT]
[INDENT][INDENT]"Segoe UI Italic (TrueType)"=""[/INDENT][/INDENT]
[INDENT][INDENT]"Segoe UI Bold Italic (TrueType)"=""[/INDENT][/INDENT]
[INDENT][INDENT][HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\FontSubstitutes][/INDENT][/INDENT]
[INDENT][INDENT]"Segoe UI"="Tahoma"[/INDENT][/INDENT]
[INDENT][INDENT]
C) In Notepad, edit Tahoma in quotes with the name of the font that you would like to use in instead with it still in quotes. (see screenshot below)​
NOTE: You can get the name of the font from the font folder location C:\Windows\Fonts. Be sure that you use the exact same font name that is listed. Do not include the Regular part in the font name. For example, I would type Impact instead of Impact Regular.
D) In Notepad, click on File (Menu bar) and Save As. (see screenshot below)​
E) Type in a name you would like with a .reg file extension (ex: Impact-Fonts.reg), then click on the Save button. (see screenshot below)​
D) Right click the created .reg file and click on Merge.​
E) Click on Yes, Yes, and OK when prompted.​
F) Log off and log on, or restart the computer to apply changes.​
3. To Restore the Default Fonts
NOTE: This will undo all changes that you made using either step 1 or step 2 above, and restore the original default fonts used by Windows 7.
Default_Fonts.reg
download
  • Set_Tahoma_Default_Font.reg
  • Default_Fonts.reg
Many thanks, Brink, for the useful information!
I'm sorry, it seems everything is not so simple. I'm running Vista Ultimate x86 with Classic Theme, so AERO and Desktop windows manager are disabled. One thing is annoying me, here is the screen:
I've applied registry hint you has described, rebooting, but the problem still here. I've checked registry again, and everything is OK. Both parameters MS Shell Dlg and MS Shell Dlg2 are Tahoma.
Maybe you're can help?
Thanks in advance
VW
Hi Verwolk,
Welcome to the Forum. :party:
Most, but not everything is affected by this change. The Run window happens to be one of them. Sorry. Did you do all of step two also to change everything else?
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
You're welcome Verwolk,
I'm still digging around the registry for other areas that affect the fonts. If I find the buggers, I'll update this tutorial to include it. Just keep checking back for updates. I'll send you a PM to if I find the one for Run.
Another newbie is there a quick way to set font defaults in works, or will the method described serve to change and lock all font settins on all the programs.
Thanks,
Les.
Hi Les,
I do not know if it will work in Works or not. All programs are different. Some use the same default as Vista, and some use their own settings. You can give it a shot to see. If it does not, then you can change them back to the default fonts if you wanted to.
Sorry, :(
Hello Shawn,
Thanks for that reply I will have try later I know it's not desperate but it is one of those silly things that buggs me there has to be a simple answer but not for a Silver Surfer like
me.
Rgards
Les.
I know how you feel about those little things. Let us know how it went for you.
I'm having the same problem as Verwolke, well i imagine its the same problem, i can't view his image completely, its only thumbnail size.
My lovely Tahoma font has been applied using your methods in the advanced appearance settings, and the registry tweaks. Credit is due there, well done for sussing that out, i can't stand cleartype in vista, so i turned it off and was left with nasty looking segoe UI everywhere.
The only places so far that don't seem to adopt the new font, are in prompt boxes and some message boxes, such as run, and the recycle bin delete confirmation box. Its driving me up the wall, i've scoured the registry for the culprit, and can't find it anywhere. Has anyone found a fix for this yet?
I've upped a screenshot of my issue, here:
link removed - no longer worked
The wordpad is open to show SegoeUI, compared with the message box, just to make sure its displaying that, when it should really be tahoma.
Any help is greatly appreciated.
Ben
Hi Brink,
Nice job. The explanation is easy. It is very visual and they are nice colors too :-)
If you want to get deeper, you may want to take a look there:
Fix Windows Vista’s Fonts! ~ Chris Pirillo
The registry fix is complete, but maybe a little harder to grasp for the beginners? Anyway do the usual registry backup (save your hives!!!) before to install the new keys.
NB: because many people complained about the change and did not have any backup, the original hives are even for you to download on a page if you do something wrong. If you don't find it, PM me and I will direct you.
I am not related with Chris Pirillo in any manner. This is not advertisement of some sort.
Cheers everyone.
Thank you Admsupport. This tip has been added to the tutorial as another option.
Hi back Brink. You are welcome.
There is ONE main difference between these 2 registry edits I try to clear up:
- Brink tutorial only changes the default system font = limited visual effect (especially under XP), BUT respects the external applications (Microsoft Office, Adobe, etc.) configuration.
- Chris fix changes the default system font and the mapping font of the OS & the APPLICATIONS = full visual effect, BUT some caveats. Wait, don't panic! I explain the changes with an example:
Office 2003 word's default template uses New Times Roman pt12, you will get Segoe UI instead (it's easy to make a new default template with your styles anyway.)
Acrobat Reader 8, 9, you will be able to read your .pdf but they will not print, unless
a. to print them as a picture (bad...)
Or
b. the font used in the PDF is not a font the .reg file substitutes for Segoe UI (i.e. Arial, New Times Roman, Thaoma, etc.) (Unlikely with 99.9% of the documents)
You have got the info, now that's a matter of taste, needs and choice.
Thank you again Admsupport. This has been added as a warning to help folks decide what option they would prefer to do.
I posted on this forum a loooong time ago, when i was having issues with my font changing in vista. The issue was the taskbar and dialog box fonts not changing to verdana like the rest of the fonts.
I scoured the registry for days, and eventually managed to get it working, but i've forgotten what i did, and know i've had to reinstall Vista, im stuck.
Has anyone managed to figure this out yet?
I thought i'd posted my solution on here, my account says i made two posts, but only one post is visible?
Ben
Hi Ben,
Sorry, but I have not found anything for the RUN box yet. :(
You go there Reverse Vista Font Fix - Vista Horizons
It will revert almost all (if not all) your changes to the default vista font settings (this is not for you, but it is related)
Beforehand, backup the full 5 keys. Do not backup the keys as (.reg) files, but as hives (*.*). In the case the result is not what you are looking for you can get back to your settings and give it a another try.
Hi!
My computer just chaged fonts( i didnt done anything)
And now everything is bold even webpages is this help?
sorry 4 my bad english
    Core 2 Duo 6600 3.0 GHz
    ATI 4870 HD Full
Hello O'Connel, and welcome to Vista Forums.
Since this has just happened, then you might do a System Restore instead using a restore point dated before this happened.
It happend bpout one month ago so i have a lot new data, if i do system restore i will loose them?
Sorry for my bad english
    ATI 4870 HD Full
