forgot login password on gateway
My roomate forgot his password on his new gateway desktop. he never set up the password recovery disk or any of that jazz? is he screwed? or is there anything he can do? thanks for your help!
Barman58
Staff member
hi mrnewgui, welcome to the vista forums :party:
Offline NT Password & Registry Editor
follow the instructions carefully - and it is vista compatible although I think the site says XP as latest OS.
    Am enjoying the Historical aspect - will update Soon
    AMD Athlon 64x2 4800+
    ALiveNF6P-VSTA
    2Gb
    One, 19"
    1360x768 @60Hz
    500 Gb SATA II
    80 Gb Maxtor
    Stock
    Old E-machines 570uk
    Stock
    MS 800 Wireless
    MS 800 Wireless
    35Mb/Sec
    Original Vista System, Now moved on to Win8 Test System and now to recycling plant :P
O
Ollis
UBCD has an NTFS account psw reset.
http://www.ultimatebootcd.com/
Also he can activate the hidden built-in Admin account for back-up.
<http://www.howtogeek.com/howto/windows-vista/enable-the-hidden-administrator-account-on-windows-vista/>
However, he shouldn't use the built-in Admin account for everyday useage.
Barman58
Staff member
Hi
have you got the .ISO file on the USB or have you burned the actual files to the stick. the ISO has to be burned to create a bootable media. have not done this with USB stick myself but should work as long as USB is enabled as bootable drive in BIOS. The is a tutorial in the tutorials section here which explains Bootable USB will try to locate it but you may want to have a look yourself as I have to rush out to the day job :D
    ALiveNF6P-VSTA
    2Gb
    One, 19"
    1360x768 @60Hz
    500 Gb SATA II
    80 Gb Maxtor
    Stock
    Stock
    MS 800 Wireless
    MS 800 Wireless
    35Mb/Sec
