Forgotten administrator password
B
BeenieKB
HELP!!!!!! I forgot the password to my ONLY USER ACCOUNT. I have windows
Vista. I cannot operate the computer through any other account, because, i
repeat, there is no other account. Is there any way to recover or reset this
password, even by restoring it to factory settings??
Any help is appreciated
P
Peter Foldes
For User type in Administrator
For Password leave it Blank
Try and see if you can enter.
Peter
Please Reply to Newsgroup for the benefit of others
Requests for assistance by email can not and will not be acknowledged.
"BeenieKB" <BeenieKB@discussions.microsoft.com> wrote in message news:0FFAC6FB-1DAC-4CB0-8AB3-F14230C8A17A@microsoft.com...
M
mrcingrace
Besides racking your brain to try and remember the password, which I am sure
you have done. The only way to restore to factory settings is to reinstall
Vista, if you have the CD (or recovery CD). Other than that, you can try
this tool to recover your password if you have access to a different computer
in order to do this:
http://www.loginrecovery.com/
Other options would be to call Windows Vista Support, but that might cost
some money.
Hope this helps, if not reply to this and let me know and I will see what I
can find!
Good Luck!
M
mrcingrace
Here is another tip once you get your situation resolved. In Windows Vista,
you can create a password recovery disk/Cd if this happens again!!
http://support.microsoft.com/kb/930381/
mrcingrace
M
mrcingrace
Hello again -
I searched through some of the answers already posted and it seems that
several people have used this tool to do what you need to do and it seems to
work, I am afraid though, if this does not, you will have to reinstall Vista
Go to http://home.eunet.no/~pnordahl/ntpasswd/
There you will find zip files that will let you create boot floppy disks or
bootable CDs
that will enable you to reset any system password on an NT class
operating system (Win2000, XP and Vista are all NT class operating system).
M
Mick Murphy
http://pcsupport.about.com/od/toolsofthetrade/tp/passrecovery.htm
The above link has 4 different ways to recocer admin passwords. Hope it helps.
The 'Knoppix Hacks' book details how to use the Knoppix Live CD to reset
the admin password on xp systems. It may work on vista, as well. You
should also be able to find online info on the, rather simple, process.
I
Insane
#8
G
gopiyadav
#9
> windows
> because, i
> reset this
hi
BeenieKB
Download Linux boot software. This is small bootable software. Make a
bootable cd and boot with the same cd. Follow the instruction and u can
reset all account passwords easily.
gopiyadav
Posted via http://www.vistaheads.com
S
Smithsonian
#10
Its your absolute only account. Wow. If you have a recovery disc stick it in
ur comp and open a command prompt. Type this
Net user Administrator newpassword
That should set the password to newpassword
"gopiyadav" <gopiyadav.36v8cy@xxxxxx-mx.forums.vistaheads.com> wrote in message
news:gopiyadav.36v8cy@xxxxxx-mx.forums.vistaheads.com...
>> windows
>> because, i
>> reset this
> hi
> BeenieKB
> gopiyadav
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
#11
Hi Insane,
This will show you how to reset your password so you can gain access again. You may need to do either Method Three or Five.
http://www.vistax64.com/tutorials/102005-reset-user-account-password.html
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
