Format Issue
  • Thread starter Brandon Shell [MVP]
  • Start date
B
Brandon Shell [MVP]
Out-File has -width parameter
You may also want the -auto flag for Format-Table
Brandon Shell
Blog: http://www.bsonposh.com/
PSH Scripts Project: www.codeplex.com/psobject
TM> I'm piping a command through Format-Table and then to Out-File. I'm
TM> asking for a single column that is pretty wide. It truncates the
TM> column and puts ... at the end. I can't remember how to expand it
TM> to give me everything.
TM>
TM> ----------------------------------------------------
TM> Thomas A. Moreau, BSc, PhD, MCSE, MCDBA, MCITP, MCTS
TM> SQL Server MVP
TM> Toronto, ON Canada
TM> https://mvp.support.microsoft.com/profile/Tom.Moreau
T
Tom Moreau
I'm piping a command through Format-Table and then to Out-File. I'm asking
for a single column that is pretty wide. It truncates the column and puts
.... at the end. I can't remember how to expand it to give me everything.
Tom
SQL Server MVP
Toronto, ON Canada
T
Tom Moreau
It's almost working. I had tried the -AutoSize parameter for Format-Table
and it didn't make any difference. However, the -Width parameter for
Out-File does. That said, I don't like the fact that it pads blanks onto
lines that are shorter than the specified width. Is there some way of
expanding that doesn't put unnecessary whitespace?
Tom
SQL Server MVP
Toronto, ON Canada
"Brandon Shell [MVP]" <a_bshell.mask@xxxxxx> wrote in message
news:29d4f64638ba8ca2800c7023b18@xxxxxx
Brandon Shell
TM>
TM> SQL Server MVP
B
Brandon Shell [MVP]
I find that its best to format the data yourself when piping to a file
I can provide you example if you gimme an idea of what your looking for.
Brandon Shell
TM> It's almost working. I had tried the -AutoSize parameter for
TM> Format-Table and it didn't make any difference. However, the -Width
TM> parameter for Out-File does. That said, I don't like the fact that
TM> it pads blanks onto lines that are shorter than the specified width.
TM> Is there some way of expanding that doesn't put unnecessary
TM> whitespace?
TM>
TM> SQL Server MVP
TM> "Brandon Shell [MVP]" <a_bshell.mask@xxxxxx> wrote in message
TM> news:29d4f64638ba8ca2800c7023b18@xxxxxx
TM> Out-File has -width parameter
TM> You may also want the -auto flag for Format-Table
TM>
TM> Brandon Shell
TM> ---------------
TM> Blog: http://www.bsonposh.com/
TM> PSH Scripts Project: www.codeplex.com/psobject
TM>> I'm piping a command through Format-Table and then to Out-File.
TM>> I'm asking for a single column that is pretty wide. It truncates
TM>> the column and puts ... at the end. I can't remember how to expand
TM>> it to give me everything.
TM>>
TM>> ----------------------------------------------------
TM>> Thomas A. Moreau, BSc, PhD, MCSE, MCDBA, MCITP, MCTS
TM>> SQL Server MVP
TM>> Toronto, ON Canada
TM>> https://mvp.support.microsoft.com/profile/Tom.Moreau
T
Tom Moreau
Right now, I'm just trying to save the command history. Where I have a
problem is if the command has a lot of characters in it. I've got the rest
down fine; it's just that width thing...
Tom
SQL Server MVP
Toronto, ON Canada
news:29d4f64638bf8ca28044f562e9f@xxxxxx
Brandon Shell
TM> whitespace?
TM>
TM> SQL Server MVP
TM>
TM> Brandon Shell
TM> ---------------
TM>>
TM>> SQL Server MVP
B
Brandon Shell [MVP]
have you looked at
Start-Transcript
http://technet.microsoft.com/en-us/library/bb978600.aspx
and
Stop-Transcript
http://technet.microsoft.com/en-us/library/bb978567.aspx
Brandon Shell
TM> Right now, I'm just trying to save the command history. Where I
TM> have a problem is if the command has a lot of characters in it.
TM> I've got the rest down fine; it's just that width thing...
TM>
TM> SQL Server MVP
TM> news:29d4f64638bf8ca28044f562e9f@xxxxxx
TM> I find that its best to format the data yourself when piping to a
TM> file
TM> I can provide you example if you gimme an idea of what your looking
TM> for.
TM>
TM> Brandon Shell
TM> ---------------
TM>> It's almost working. I had tried the -AutoSize parameter for
TM>> Format-Table and it didn't make any difference. However, the
TM>> -Width parameter for Out-File does. That said, I don't like the
TM>> fact that it pads blanks onto lines that are shorter than the
TM>> specified width. Is there some way of expanding that doesn't put
TM>> unnecessary whitespace?
TM>>
TM>> SQL Server MVP
TM>> "Brandon Shell [MVP]" <a_bshell.mask@xxxxxx> wrote in message
TM>> news:29d4f64638ba8ca2800c7023b18@xxxxxx
TM>> Out-File has -width parameter
TM>> You may also want the -auto flag for Format-Table
TM>> Brandon Shell
TM>> Blog: http://www.bsonposh.com/
TM>> PSH Scripts Project: www.codeplex.com/psobject
TM>>> I'm piping a command through Format-Table and then to Out-File.
TM>>> I'm asking for a single column that is pretty wide. It truncates
TM>>> the column and puts ... at the end. I can't remember how to
TM>>> expand
TM>>> it to give me everything.
TM>>> ----------------------------------------------------
TM>>> Thomas A. Moreau, BSc, PhD, MCSE, MCDBA, MCITP, MCTS
TM>>> SQL Server MVP
TM>>> Toronto, ON Canada
TM>>> https://mvp.support.microsoft.com/profile/Tom.Moreau
S
Shay Levi
Try
format-table -auto -wrap
Shay Levi
$cript Fanatic
http://scriptolog.blogspot.com
> Wow! I did not know that! Thanx!
> That said, I'm still wondering how to make the complete width of a
> wide column show up, regardless of whether or not I'm saving to a
> file.
> SQL Server MVP
> Toronto, ON Canada
> news:29d4f64638c58ca2808c41fdd8f@xxxxxx
> have you looked at
> Start-Transcript
> and
> Stop-Transcript
> Brandon Shell
TM>> Right now, I'm just trying to save the command history. Where I
TM>> have a problem is if the command has a lot of characters in it.
TM>> I've got the rest down fine; it's just that width thing...
TM>>
TM>> SQL Server MVP
TM>> news:29d4f64638bf8ca28044f562e9f@xxxxxx
TM>> I find that its best to format the data yourself when piping to a
TM>> file
TM>> I can provide you example if you gimme an idea of what your looking
TM>> for.
TM>> Brandon Shell
TM>>> It's almost working. I had tried the -AutoSize parameter for
TM>>> Format-Table and it didn't make any difference. However, the
TM>>> -Width parameter for Out-File does. That said, I don't like the
TM>>> fact that it pads blanks onto lines that are shorter than the
TM>>> specified width. Is there some way of expanding that doesn't put
TM>>> unnecessary whitespace?
TM>>>
TM>>> "Brandon Shell [MVP]" <a_bshell.mask@xxxxxx> wrote in message
TM>>> news:29d4f64638ba8ca2800c7023b18@xxxxxx
TM>>> Out-File has -width parameter
TM>>> You may also want the -auto flag for Format-Table
TM>>> Brandon Shell
TM>>> Blog: http://www.bsonposh.com/
TM>>> PSH Scripts Project: www.codeplex.com/psobject
TM>>>> I'm piping a command through Format-Table and then to Out-File.
TM>>>> I'm asking for a single column that is pretty wide. It truncates
TM>>>> the column and puts ... at the end. I can't remember how to
TM>>>> expand
TM>>>> it to give me everything.
TM>>>> ----------------------------------------------------
TM>>>> Thomas A. Moreau, BSc, PhD, MCSE, MCDBA, MCITP, MCTS
TM>>>> SQL Server MVP
TM>>>> Toronto, ON Canada
TM>>>> https://mvp.support.microsoft.com/profile/Tom.Moreau
T
Tom Moreau
#8
That said, I'm still wondering how to make the complete width of a wide
column show up, regardless of whether or not I'm saving to a file.
Tom
SQL Server MVP
Toronto, ON Canada
have you looked at
Start-Transcript
and
Stop-Transcript
Brandon Shell
TM>
TM> SQL Server MVP
TM> file
TM> for.
TM>
TM> Brandon Shell
TM> ---------------
TM>>
TM>> SQL Server MVP
TM>> Brandon Shell
TM>>> expand
T
Tom Moreau
#9
That's not bad, but as its name implies, it wraps to the next line. I'd
like it just to give me the full width without wrapping.
Tom
SQL Server MVP
Toronto, ON Canada
"Shay Levi" <no@xxxxxx> wrote in message
news:8766a9441aada8ca28449cfc0428@xxxxxx
Try
Shay Levi
$cript Fanatic
> file.
> SQL Server MVP
> Toronto, ON Canada
> have you looked at
> Start-Transcript
> and
> Stop-Transcript
> Brandon Shell
TM>>
TM>> SQL Server MVP
TM>> file
TM>> for.
TM>> Brandon Shell
TM>>>
TM>>> Brandon Shell
TM>>>> expand
S
Shay Levi
#10
You can out-file with a -width enough to accommodate the longest string.
Shay Levi
$cript Fanatic
> I'd like it just to give me the full width without wrapping.
> SQL Server MVP
> Toronto, ON Canada
> news:8766a9441aada8ca28449cfc0428@xxxxxx Try
> Shay Levi
> $cript Fanatic
>> file.
>> SQL Server MVP
>> Toronto, ON Canada
>> have you looked at
>> Start-Transcript
>> and
>> Stop-Transcript
>> Brandon Shell
TM>>> Right now, I'm just trying to save the command history. Where I
TM>>> have a problem is if the command has a lot of characters in it.
TM>>> I've got the rest down fine; it's just that width thing...
TM>>>
TM>>> news:29d4f64638bf8ca28044f562e9f@xxxxxx
TM>>> I find that its best to format the data yourself when piping to a
TM>>> file
TM>>> I can provide you example if you gimme an idea of what your
TM>>> looking
TM>>> for.
TM>>> Brandon Shell
TM>>>> It's almost working. I had tried the -AutoSize parameter for
TM>>>> Format-Table and it didn't make any difference. However, the
TM>>>> -Width parameter for Out-File does. That said, I don't like the
TM>>>> fact that it pads blanks onto lines that are shorter than the
TM>>>> specified width. Is there some way of expanding that doesn't put
TM>>>> unnecessary whitespace?
TM>>>>
TM>>>> "Brandon Shell [MVP]" <a_bshell.mask@xxxxxx> wrote in
TM>>>> message
TM>>>> news:29d4f64638ba8ca2800c7023b18@xxxxxx
TM>>>> Out-File has -width parameter
TM>>>> You may also want the -auto flag for Format-Table
TM>>>> Brandon Shell
TM>>>> Blog: http://www.bsonposh.com/
TM>>>> PSH Scripts Project: www.codeplex.com/psobject
TM>>>>> I'm piping a command through Format-Table and then to Out-File.
TM>>>>> I'm asking for a single column that is pretty wide. It
TM>>>>> truncates
TM>>>>> the column and puts ... at the end. I can't remember how to
TM>>>>> expand
TM>>>>> it to give me everything.
TM>>>>> ----------------------------------------------------
TM>>>>> Thomas A. Moreau, BSc, PhD, MCSE, MCDBA, MCITP, MCTS
TM>>>>> SQL Server MVP
TM>>>>> Toronto, ON Canada
TM>>>>> https://mvp.support.microsoft.com/profile/Tom.Moreau
T
Tom Moreau
#11
As I reported earlier, I don't want the extra baggage of the padded blanks.
Also, what if I don't know what the widest field is going to be?
Tom
SQL Server MVP
Toronto, ON Canada
news:8766a9441aae28ca2847f47366ee@xxxxxx
Shay Levi
$cript Fanatic
> SQL Server MVP
> Toronto, ON Canada
> Shay Levi
> $cript Fanatic
>> file.
>> SQL Server MVP
>> Toronto, ON Canada
>> have you looked at
>> Start-Transcript
>> and
>> Stop-Transcript
>> Brandon Shell
TM>>>
TM>>> file
TM>>> looking
TM>>> for.
TM>>> Brandon Shell
TM>>>>
TM>>>> message
TM>>>>> truncates
TM>>>>> expand
T
Tom Moreau
#12
I've played with this a bit and what it does is output the command as well
as the output produced by the command. It should give you the option of
just the command.
Tom
SQL Server MVP
Toronto, ON Canada
have you looked at
Start-Transcript
and
Stop-Transcript
Brandon Shell
TM>
TM> SQL Server MVP
TM> file
TM> for.
TM>
TM> Brandon Shell
TM> ---------------
TM>>
TM>> SQL Server MVP
TM>> Brandon Shell
TM>>> expand
S
Shay Levi
#13
You can get just the CommandLine column with the -property parameter:
get-history | format-table -auto -wrap commandLine | ...
All Format-* cmdlets will pad spaces, it's by design. They are best suited
for console display.
If you need to format it the way you want, you'll have to write your own
code.
If only one column is needed, try this:
get-history | foreach { $_.commandLine } | set-content .\commands.txt
Shay Levi
$cript Fanatic
> well as the output produced by the command. It should give you the
> option of just the command.
> SQL Server MVP
> Toronto, ON Canada
> have you looked at
> Start-Transcript
> and
> Stop-Transcript
> Brandon Shell
TM>>
TM>> SQL Server MVP
TM>> file
TM>> for.
TM>> Brandon Shell
TM>>>
TM>>> Brandon Shell
TM>>>> expand
T
Tom Moreau
#14
Aha! That last one worked:
Thanx much!
Tom
SQL Server MVP
Toronto, ON Canada
news:8766a9441aae68ca284d1283aa2c@xxxxxx
code.
Shay Levi
$cript Fanatic
> SQL Server MVP
> Toronto, ON Canada
> have you looked at
> Start-Transcript
> and
> Stop-Transcript
> Brandon Shell
TM>>
TM>> SQL Server MVP
TM>> file
TM>> for.
TM>> Brandon Shell
TM>>>
TM>>> Brandon Shell
TM>>>> expand
K
Keith Hill [MVP]
#15
"Tom Moreau" <tom@xxxxxx> wrote in message
news:eShS0IiWIHA.5448@xxxxxx
> blanks.
I've done this before to widen the output and trim off unnecessary spaces:
ghy -count 999 | select CommandLine | out-string -stream -width 999 |
%{$_.TrimEnd()} | Out-file commands.txt
Keith
K
Kiron
#16
Try this:
h -c (h -c 1).id | % {"$_".trimEnd()} > History.txt
# or...
h -c (h -c 1).id | % {$_ -replace ' +$'} > History.txt
Kiron
