format partition where OS is installed
ruined
Hi guys,
I have a question. If I format the partition where my OS is installed, will my other programs/softwares installed in other partition get affected?
I want to reformat and reinstall my OS but I'm not sure if I will be able to run my programs and softwares just as if nothing happened!
Hope someone could help me on this! Thanks in advance!
pooch
Old Dog
Hi Ruined,
When you format your partition to reinstall your OS The other partitions will stay as they are, as long as you do not format them during the new install.
However if you have installed programs to another partition and then reinstall the OS, The "new" OS will not know this, making these programs as good as useless. Ie, the old programs will not show up in the new menu, nor will they be registered in the registry. So yes you would have to reinstall them.
This said, if you only have data files. Ie, a collection of music, pictures, films or Back up files on another partition these will remain untouched and you will be able to access these files again with the new OS.
I hope this helps
Pooch
    Self build
    Asus M3A32-MVP Deluxe
    8 gig Samsung PC800 RAM
    NVidia 9600gt
    AD1988b
    1680 : 1050 1280 : 1024
    Drive #1 - SAMSUNG HD252HJ (250 GB)
    Drive #2 - Hitachi HDT721010SLA360 (1000 GB)
    Drive #3 - SAMSUNG HD250HJ (250 GB)
    Drive #4 - SAMSUNG HD103UJ (1000 GB) External eSATA
    Enermax Chakra
    Easy Line Laser Mouse
    Standard
    I have also used Fedora, Suse, Ubuntu Linux
    And all other Windows from 95 to date except ME
SIW2
Hi guys,
Hi Ruined,
I hope this helps
Pooch
Hi Ruined
Programs that were installed on your D partition will not be in the registry of the newly installed o\s on the C partition.
However I have no problem running them as executables from the D partition. Depending on which programs you have, you may find there are some that won't and need to be reinstalled.
( This does not include my security apps. , which I always install on the same partition as the o/s - so they need reinstalling ).
You may find it easier to create shortcuts to the .exe files and place them on your desktop. Alternatively, making a shortcut to the D drive and putting it in Quick launch works well.
Hope this helps
SIW2
    Intel E8400
    ASRock1333-GLAN R2.0
    2gb DDR2 800
    nvidia 9500GT 1gb
