Function Int fails ?
M
massimoxr1
Hi to all,
this is the code in my file test.vbs :
Dim Result
Result = (2170.12 / 9.08) ' is 239
msgbox("(2170.12 / 9.08) =**" & Result & "**")
msgbox("Int(Result) =**" & Int(Result) & "**") ' Ok
Result = (2179.2 / 9.08) ' is 240
msgbox("(2179.2 / 9.08) =**" & Result & "**")
msgbox("Int(Result) =**" & Int(Result) & "**") ' Error! Why 239 ?
Result = (2188.28 / 9.08) ' is 241
msgbox("(2188.28 / 9.08) =**" & Result & "**")
Any ideas?
Thanks!
M
mayayana
Int rounds the number. If you switch the
slashes to backslashes you'll get yet another
result. That's what's supposed to happen. An
integer is a whole number.
> Dim Result
> Any ideas?
> Thanks!
R
Richard Mueller [MVP]
<massimoxr1@xxxxxx> wrote in message
news:ac348705-c661-43f1-89ce-96f49507f88a@xxxxxx
> Hi to all,
> Dim Result
> Any ideas?
> Thanks!
The behaviour is expected. All math internally is in binary and the results
is often inexact. Internally, the result is closer to 239.9999999999999.
Note that Int((2179.2 / 9.08) + .0000000000001) is 240.
Richard Mueller
MVP Directory Services
Hilltop Lab - http://www.rlmueller.net
M
massimoxr1
ok, and what about the function CInt ?
msgbox("CInt(Result) =**" & CInt(Result) & "**") 'returs 240
CInt seems to return the right value.
E
ekkehard.horner
Straight from the Docs (CInt Function):
CInt differs from the Fix and Int functions, which truncate,
rather than round, the fractional part of a number. When the
fractional part is exactly 0.5, the CInt function always rounds
it to the nearest even number. For example, 0.5 rounds to 0,
and 1.5 rounds to 2.
R
news:4e4f6b9d-5adc-439a-8dac-3b4de1686c0b@xxxxxx
CInt rounds, while Int (and also Fix) does not.
Richard Mueller
R
"Richard Mueller [MVP]" <rlmueller-nospam@xxxxxx> wrote in
message news:uX0YMH$HJHA.4936@xxxxxx
> Richard Mueller
Also, CInt can only handle values between -32,768.5 and 32,767.5 (the result
must be datatype integer). The Int and Fix functions can handle any numeric
values.
Richard Mueller
