function return values, console output
  • Thread starter =?Utf-8?B?ZnV6enkzMzM=?=
  • Start date
I'm trying to figure out how to run msbuild in a function and have this
function return true or false indicating msbuild's success or failure.
Also important, I want the normal output of the command (streaming and
with intended foregroung/background color) to appear in the console as
msbuild is running so, for example:
function Compile() {
msbuild
if( $LastErrorCode -eq 0 ) {
return $true
} else {
return $false
#$compileSuccess = Compile
Compile
Calling "Compile" without assigning it to a variable I get the behavior that
I'm looking for, but no return value. However calling Compile and assigning
the return value to $compileSucsess as in the commented line in the example
causes all output from msbuild from to be stored in $compileSuccess variable,
not just the boolean return value, and msbuild's output doesn't appear in the
console as intended.
So how can I acheive the behavior I'm looking for? Is there a way to simply
return a value, not all output from the function?
=?Utf-8?B?L1wvXG9cL1wvIFtNVlBd?=
You are putting the output and the boolean to the pipeline
(return is optional all output gets returned.
you can use
MSbuild | out-host
this will output the test to the console but not the pipeline
MowPS>Function test {
>> ipconfig | out-host
>> return $true
>> } else {
>> return $false
MowPS>test
Windows IP Configuration
Ethernet adapter Local Area Connection:
False
MowPS>$test = test
MowPS>$test
False
b.t.w. this also has the lineadding bug theat is bothering a lot of the
powershell output.
Greetings /\/\o\/\/
> msbuild
> return $true
> } else {
> return $false
> Compile
K
Keith Hill [MVP]
"/\/\o\/\/ [MVP]" <oMVP@discussions.microsoft.com> wrote in message
news:3B33C30E-393F-4398-A9FF-0323EC388D41@microsoft.com...
> powershell output.
You can say that again. :-)
Keith
Thanks for replying but this doesn't address the issue.Using out-host in this
manner causes output to be buffered before it get to out-host, so it appears
in one big glob when msbuild is done, and all of the coloring that is done by
msbuild to it's output is also lost in this scenario.
Here's a little something I found though.
https://connect.microsoft.com/feedback/ViewFeedback.aspx?FeedbackID=77986&SiteID=99
I think this addresses what I want, simply that msbuild writes to the
console directly, which would allow it to behave exactly as it did in cmd.exe.
> you can use
> MSbuild | out-host
> >> ipconfig | out-host
> >> return $true
> >> } else {
> >> return $false
> MowPS>test
> False
> MowPS>$test = test
> MowPS>$test
> False
> powershell output.
> Greetings /\/\o\/\/
> > msbuild
> > return $true
> > } else {
> > return $false
> > Compile
