Functions: Taking input from the Pipe
  • Thread starter Christian Schindler
  • Start date
C
Christian Schindler
I'm working a lot with Exchange 2007 and when I retrieve an object and format
it with FL I get back a list of properties - but also properties that I'm not
interested in(for example GUID, etc).
So I normaly use SELECT to exclude those properties. However, specifying the
properties ever and ever again is a bit boring...
My idea was to write a function to have the same select command available
all the time... here is the function:
function esl {
select * -ExcludeProperty
Guid,ObjectCategory,ObjectClass,WhenChanged,WhenCreated,ExchangeVersion,DistinguishedName
Now my problem is that the function does NOTHING. It seems as if it doesn't
take input from the pipe. I tried with SELECT -InputObject $_ - with no
success...
Any help would be appreciated!
TIA
Christian
V
Vadims Podans
your function does not receive any objects from pipe. You should specify
that pipeline is the source:
function esl {
$input | select * -ExcludeProperty
$input contains all objects that was received from pipeline.
WBR, Vadims Podans
PowerShell blog - www.sysadmins.lv
"Christian Schindler" <ChristianSchindler@xxxxxx>
rakstÄ«ja ziņojumÄ
"news:B4FE516D-ADC7-4007-97E1-A42834FA5B70@xxxxxx"...
> format
> not
> the
> function esl {
> doesn't
> success...
> TIA
> Christian
