Game Explorer stopped working!
J
Jake Eyre
My Vista Game Explorer has stopped working. When I d-click on a game in there
now, I get the following error:
"This file does not have a program associated with it for performing this
action. Create an association in the Set Associations control panel"
This happens for installed games and Windows Vista ones.
I have Ultimate on a clean-install.
Also, where is Texas Hold 'Em??
Thanks
J
Jake Eyre
Thanks for the reply, Steve,
I am unable to either create links nor delete the ones that are in
there..What is the real path of the folder?
Do you know where Texas Hold 'Em is?
"Steve" wrote:
> Try recreating a manual link in Games Explorer to the game. I dont think
> dragging and dropping works very well.
> hope this helps
> Steve
> Steve
> http://www.vistaheads.com
J
Jane C
Jake, did you do a registry tweak or use a 3rd party tweak to remove the
shortcut arrow overlays on desktop icons? If you removed the "IsShortcut"
key, then that is why your games links no longer work in Game Explorer.
Jane, not plain ;) 64 bit enabled :-)
Batteries not included. Braincell on vacation ;-)
"Jake Eyre" <JakeEyre@discussions.microsoft.com> wrote in message
news:B06203D7-530A-4FC7-80FE-1DFB510F9225@microsoft.com...
>> hope this helps
>> Steve
>> Steve
J
Jake Eyre
That would be it :)
Can't help but tweak a bit. Thanks, Jane
> >> hope this helps
> >> Steve
> >> Steve
