Game problems on vista...
ncool
6
hey forum...I have been experiencing a serious problem on my computer... cant launch most of the games... MMOs seem to have mo problem.. but other games just don't launch... when i start them i just get a blank screen(no cursor, no video, no audio, nothing) and this is not my computer problem cuz i have the same update on my hp laptop and its having the same problem..... both my pc and the laptop are high performance computers.... all semed to be fine but one day all games just stoped launching... so if you got sugestions please help.. :(:(:(:(:(:(:(:(:(
Chase
americano
1,571
Location
Merced & Monterey, CA
Can you post your system specs for us. (especially your video card info)
If you know how, update your display drivers.
Which games are you trying to run and what are the minimum system requirements for them?... Moreover, what are they compared to your system..?--Post your system specs plz
    HP Pavilion Elite
    Some Amount of Motherness
    6.O GB RAM
    Some Amount of Soundness
    1440x900 & 1440x900
    WD Caviar Blue 500GB
    Some Amount of Voltageness
    Hp Pavilion Elite Case
    Some Amount of Coolingness
    HP: M/N:M-SBQ133
    HP: Model Number: KB0911
    Comcast: 20 MB/S
tom982
٩(͡๏̯͡๏)۶
3,642
Location
England
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    Samsung EVO 128GB SSD
    Seagate Barracuda 2TB 7200rpm
    NZXT Phantom 410
ncool
6
thnx for the replys guys.... well its not that they didnt launch from the start.... everything was ok untill one day everything stopped working... games like: Devil May Cry 4, X-blades, Split second and etc...
tom982
٩(͡๏̯͡๏)۶
3,642
Location
England
So is the problem solved?
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
tom982
٩(͡๏̯͡๏)۶
3,642
Location
England
#8
Would you be able to upload a few screenshots for us?
First screenshot:
1. Open the start menu
2. Type msconfig.exe in the search box and hit enter
3. Click on the start up tab
4. Take a few screenshots so we can see the whole list
Second screenshot:
1. Press: Control + Shift + Escape
2. Click on the processes tab
3. Select show processes from all users
4. Accept the UAC prompt
5. Take a few screenshots so we can see the whole list
Screenshot 3:
2. Click control panel
3. Click programs
4. Click programs and features
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
ncool
6
#10
I think it hapened after an update of vista... though i am not sure... but it has hapened on both my computers... and both are realy good computers... and it all hapened at the same time... virus maybe?
tom982
٩(͡๏̯͡๏)۶
3,642
Location
England
#11
There should be a button on your keyboard called "Prnt Scrn"
That will take a picture of your screen and put it on your clipboard. From there you will need to open paint and paste it there, and save it as a jpeg.
Alternatively you could use a program called Hypersnap. HyperSnap - Free software downloads and software reviews - CNET Download.com
Yes, there is a possibility of you having a virus, but lets try to rule out software errors first.
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
tom982
٩(͡๏̯͡๏)۶
3,642
Location
England
#13
Reinstalling an operating system should be a last option, most problems have a solution, it can take a while to find that solution. You shouldn't lose hope so fast.
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
DravenWraith
Gaming 101
31
Location
Georgia
#14
Depending on your version of windows you have several options to make screen shots. From the Start Search type in SNIPPING TOOL, this is a screen capture tool. If you don’t have that then go to the screen you want to capture and press the PRINT SCREEN button on the keyboard, then go to the START Search and type PAINT, this is windows paint utility, once in PAINT go to edit and paste, the screen will fill up. Then just edit the picture and save.
Check to see if your video drivers are up to date.
You were running the games before you updated?
Do you know when you updated?
If you know the date you can uninstall the update from the Programs and Features then, View installed updates. This is where you can uninstall them, to see if it works. Don’t worry about them, Microsoft Update will be bugging you to reinstall them.
    HP Pavilion M9040N Elite Desktop PC
    2.4 GHz Intel Core 2 Quad Processor Q6600
    Intel G33 Express Chipset
    4 GB RAM DDR2-SDRAM PC5300 @ 667Mhz
    Nvidia 8800 GTS 640 MB
    HP 22'' Widescreen
    1680X1050
    Serial ATA Dual 320 GB hard drives (640 GB total) and HP HD3000S Personal Media Drive 300 GB USB 2.0 External Hard Drive
    Standard HP Case
    3 Fans and heat sink
    Microsoft Compact Optical Mouse 500
    Microsoft Comfort Curve Keyboard 2000
    DSL 2GB
    Upgraded the power supply to 600Watt, in order to get the Nvidia 8800 graphics card to run. And added 1GB of memory even through 32 bit Vista will not use it all.
591
Location
United States
#15
If this happened on a windows update, try system restoring before the update was applied. If that doesn't work, check your video drivers.
    Hp pavillion a6110n
    amd athlon 64 x2 live! 4400+
    4 gigs 3.3 useable
    generic pnp monitor
    7.2k rpm
    1 linux ubuntu partition
    1 vista partition
    1recovery partition
    1 windows 7 partition
    1linux swap partition
    500W, antc earthwatts EA500
    normal black case
    fans
    saitek cyborg gaming keyboard
    dsl
    2.3 ghz amd
DravenWraith
Gaming 101
31
Location
Georgia
#16
Screen Capture on Vista. You have a couple of options depending on your version of Vista, SNIPPING TOOL and PRINT SCREEN button on your keyboard, with the second you will need to open PAINT and EDIT then PASTE, to see your screen shot.
Now onto your problem, Both PC was affected at the same time? What was the commonality? Was it just the updates, which is an easy fix or virus? Also an easy fix. Retrace your steps on the first PC you encountered the problem, did you do the same steps on the Lap Top? Are you running the same software and operating system on both systems?
Virus infection, scan with an antivirus program, I recommend ESET NOD32 www.ESET.com .
If not infected then let’s look at one of the PC’s first. You have some options here as well, you can uninstall the updates one at a time from the Programs and Features, open and look under TASK, VIEW INSTALLED UPDATES, Maximize the window so you can see the dates. Hopefully you know the date this first occurred. And yes there are a lot of updates. You can uninstall one at a time; try your program to see any change. Or option 2, Do a Systems Restore, Choose a restore point right before you lost your system. Its located under Accessories, Systems Tools, and System Restore.
If your 1st PC works right duplicate the process on the other PC.
    HP 22'' Widescreen
    1680X1050
    Standard HP Case
    DSL 2GB
