Gateway Laptop (running Vista) Memory Card Reader Slot Not Working
M
Melly
I insert my SD Memory Card from my camera into my memory card reader slot on
the side of my Gateway laptop, and NOTHING happens. It sounds like it's
'working', but nothing pops up, I don't see anything when I go to My
Computer, no extra drives, nothing.
I'm running Windows Vista Home Premium on the laptop, if that makes a
difference or not...
I don't know what to do or how to get it to work. I've tried finding
information all over the place and I can't find anything. Super frustrating.
Any help/suggestions/advice??
Thank you in advance!! :)
C
Curious
While using the camera did you format the card for use in Windows?
"Melly" <Melly@xxxxxx> wrote in message
news:0B37427C-7E1A-4B47-8586-699CD8601FB5@xxxxxx
>on
> frustrating.
Clevo
Vista Fan
551
While it should work if you are desperate to upload the pictures into the PC leave the SD card in the camera and connect the two using the usually supplied USB cable.
M
Melly
Re: Gateway Laptop (running Vista) Memory Card Reader Slot Not Wor
I can't format the card for use in Windows while I use the camera... It's a
Canon.
> >on
> > frustrating.
M
Melly
Understandably so, seeing as how I normally would handle the task of
uploading pictures from my camera to my computer; however, unfortunately I've
misplaced the USB cable that came supplied with the camera, and I need the
pictures on my camera as soon as possible due to unforeseen family
complications.
I also understand that in theory it *should* work, but unfortunately it
isn't... which is why I've posted the question/problem to see if someone knew
the answer as to why it is not working.
> > slot on
> > frustrating.
> Clevo
> ___________________________
> Windows Vista Home Premium x64 + SP1
> ASUS P5K MB
> Intel Core2 Quad Q6600 @ 2.4GHz
> 4GB RAM (DDR2)
> NVIDIA GeForce 8600 GTS
> Realtek HD onboard sound
> Helpful links:
> http://windowshelp.microsoft.com/Wi...5a49-8f61-45cc-8a7d-38c4695ba9291033.mspx#EEE
JohnS
1
The problem of non-functional built-in card readers in laptops seems to be fairly common, whether the operating system is Vista or XP. In my laptop, the reader worked OK with a memory stick card, but not an SD card. When an SD card was inserted, the slot was totally dead. I gave up for a while and bought an external card reader that plugged into a USB port, but now the problem has been solved. It took a while to find the fix for my Gateway MX3560 laptop.
Fix: In many Gateway laptops, and in a lot of other brands of laptops, the flash card readers is a Texas Instruments PCIxx21 Integrated FlashMedia Controller. The xx will be numbers, but the same driver seems to work for a variety of models. Look in your Control Panel, System, Device Manager to see if that is the kind of reader that you have. The problem was that the original TI drivers just did not work, and the Gateway.com web site did not list the updated driver for my laptop model. However, the right driver was buried deep in the site. To find it, first select Support, then Drivers & Downloads. In the drivers & downloads search box, enter "TI Media Card Reader Driver". I selected the driver D20009-000-001.exe, dated 5/8/2009, downloaded it, and followed the directions to install. Success! The card reader works perfectly now !!! Good luck with your laptop.
