General guide for installing h/w on Vista-64?
After trying to install drivers for an HP printer resulting in a total wipe out and reinstall, the Asus tech called me and suggested this guide. He said to always try to connect the new device and see if Vista-64 "sees it" properly, and then uses the Vista drivers.
There should be no compatibility problems. But if Vista-64 "cannot" recognize it, one had better go to the device site and ensure it's 64 bit compatible and if new drivers exist.
Otherwise, forcing the install could lead to problems.
Sounds good to me, and I follow it.
Any opinions?
    Asus G50Vt plus two XP shop machines used for trouble-shooting client problems
lordbob75
Lord of Bobs
Vista Pro
In my Fortress
Posts
1,676
Hello again Robert.
I do agree with this, no sense in installing more drivers if it works as is. Vista (and Seven) have great built in drivers, and I have not had a device (just one, bio scanner) that has not plugged and played.
If you have something (like my mouse/KB/mobo/biometric) that has extra stuff, then add the driver.
~Lordbob
    ASUS P5QC
    2x2GB
    NVidia GeForce 9500GT 1Gb
    Mobo
    Samsung SyncMaster 206bw
    Samsung SP2514N ATA 250Gb 7200RPM
    Samsung [Model] 1Tb 7200RPM SATA2
    Razer Lachesis
    Razer Tarantula
    not fast enough
roy69
47,65,65,6B
uk
Posts
2,607
Always check before you buy something that it is compatable with vista.;)
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
    Creative Inspire 7.1 T7900 Speakers
    Trust Graphics Tablet
Posts
55
The problem with always using the Vista provided drivers is that there are often additional controls, features or tools that are available using OEM drivers vs Microsoft drivers. Case in point my current webcam which has some glitches with the Microsoft driver and does not allow me advanced settings and controls. Bad part is that the OEM driver isn't very good and causes the device to stop working from time to time. The 32bit OEM driver works fine in a 32bit setting.
I would agree that it's best to let the vista driver load first, making sure you can get the hardware to work. But if there is a signed 64 driver for the device I'd give it a shot too, you can always roll-back if it's buggy.
    AMD Phenom x4 9600 Agena
    Asus M3A-H/HDMI
    8GB OCZ Fatal1ty PC2-6400
    Powercolor Radeon HD4830
    HP W2408h, Gateway VX1100
    1920x1200, 1600x1200
    Maxtor 200GB IDE (x2)
    WD Caviar SE16 640GB SATA (x2)
    CoolerMaster eXtreme Power Plus 500w
    CoolerMaster ATCS 210
    MS Wireless Mouse for Bluetooth
    MS Wireless Keyboard for Bluetooth
lordbob75
Lord of Bobs
Vista Pro
In my Fortress
Posts
1,676
I agree. But it there are no advanced features and it works? Leave it. :)
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
