Generic Host Process for Win32 Services has encountered a problem
  • Thread starter John from Stockton, CA
  • Start date
J
I updated my Windows XP home from SP2 to SP3. From then on, whenever I put my
laptop into standby or hibernate mode, I get disconnected to the internet and
it can't renew its IP unless you restart the system. This annoys me very
much. In effect, I can't put my pc into standby/hibernation mode to save
power. Please help me with this.
error signature
EventType : BEX P1 : svchost.exe P2 : 5.1.2600.5512 P3 : 48025bc0
P4 : wzcsvc.dll P5 : 5.1.2600.5512 P6 : 4802a177 P7 : 000337b4
P8 : c0000409 P9 : 00000000
technical info
C:\DOCUME~1\Juliette\LOCALS~1\Temp\WER5136.dir00\svchost.exe.mdmp
C:\DOCUME~1\Juliette\LOCALS~1\Temp\WER5136.dir00\appcompat.txt
G
Glenn
I have this same exact problem also. I have an HP DV8000. Has anyone got
this issue resolved yet????
C
conrad
RE: Generic Host Process for Win32 Services has encountered a prob
Sorry, I can only report I also have this exact problem. I'm afraid
uninstalling sp3 will cost me days. Hoping for advice...
D
Doug
I am have been exoeriencing the same issue for several weeks. I thought that
I would find a solution...not looking that way.
S
Styan
I was having the same issue with on my Toshiba Portege M200 tablet pc.
(Running SP3 Tablet Edition). When I found out the wireless zero config
service was causing the error, I decided to rollback its version by finding a
copy of the files on an SP2 machine.
On the SP2 machine: Find the files wzcdlg.dll, wzcsapi.dll, wscsvc.dll from
c:\windows\system32\ and copy them to a USB stick.
Boot the SP3 machine in Safe Mode, go to the same folder as above. Find the
three files and rename their extensions. I renamed mine to wzcdlg.dll_sp3,
wscsapi.dll_sp3 and wscsvc.dll_sp3. (*you may need to turn off the "hide
extensions of known file types" setting in Tools...Folder Options... View
Tab*). Once you have renamed the old files, Copy the SP2 files from the USB
stick to the system32 folder.
I also copied svchost.exe, but I don't think this was causing the problem.
Reboot the machine, try putting it in standby/hibernate, and waking it up
again.
Hope this helps.
E
ekrmeyer
Re: Generic Host Process for Win32 Services has encountered a prob
I am having this problem. Do you know where I can download these
files? Don't have ready access to a sp2 machine.
S
Styan
In this line here:
P1: is the application that caused the fault.
P2: is the version
not sure what P3 is
P4: is the module being run by svchost.exe
P5: again the version
wzcsvc.dll is the wireless zero config service .dll file.
E
Ethan a Winslow sr
i have been haveing nothing bet trouble with this sence it was
downlaoded and cann,t stay on line and cann,t bring my comp to do a
system restore eather this is what the error says event type :bex p1
ixplore.exe p2 7.0.6000.16735 p3 48acc122 p4_hepler.dll p5 4.0.0.0 p6
4921bdcf p70000c219 p8 c000049 p9 00000000 so what can i do now ,
getting me very mad now its been days now ty for any imformation i will
be waiting to hear fromyou soon i hope
K
Kaz
I was having the same issue with on my Dell INSPIRON 6000 Lap-top pc.
(Running Windows XP SP3 Home Edition).
Base on Styan input, What I did is that I opened my computer or explore and
then click Find. I type as *wzcdlg*;*wzcsapi*;*wzcsvc*. I seeked these three
files under C: drive but only found two files that wzcsapi.dll and wzcsvc.dll
in C:\WINDOWS\Driver Cache\sp2.cab.
I copied the two files and then pasted the files in c:\windows\system32
after I renamed the two files which are wzcsapi.dll and wzcsvc.dll fisrt like
Styan did (my case was not three files, only two files that mentioned above).
I hope this helps you out.
O
ohillary
> again.
> Hope this helps.
> --Styan
> > > > > error signature
> > > > > technical info
