getDetailsOf method does not work
G
God Itself
i wrote a module-function (VBA) using method GetDetailsOf():
Set FSO = CreateObject("Scripting.FileSystemObject")
If FSO.FileExists(filePath) Then
strParent = FSO.GetParentFolderName(filePath)
strArgFileName = FSO.GetFileName(filePath)
With CreateObject("Shell.Application").Namespace(strParent)
Picturedimensions = .GetDetailsOf(.ParseName(strArgFileName), 26)
End With
End If
Set FSO = Nothing
GetDetailsOf returns (don't know why) empty string.
Antivir checked, firewall checked, path and references also... and no idea
Here is quite a solution to similar case but it does not work: http://209.85.229.132/search?q=cach...tailsof+empty+string&cd=2&hl=pl&ct=clnk&gl=pl
regards
J
Joe Fawcett
This group is VBScript rather than VBA but your code is more or less
agnostic between the two.
I would get rid of the 'With part' and use full references and smaller
steps. Then see what you have at each stage.
For example:
Dim item
Set item = CreateObject("Shell.Application").Namespace(strParent)
Now examine item in the debugger to see if it's what you expect.
Joe Fawcett (MVP - XML)
http://joe.fawcett.name
"God Itself" <god@xxxxxx> wrote in message
news:gqiade$bt3$1@xxxxxx
> Hi,
> End With
> End If
> Set FSO = Nothing
> regards
G
God Itself
i know that code is written in VBA (not in VBS) but the problem is not the syntax but reference to function GetDetailsOf
there is "something" in my system what blocks this function. GetDetailsOf(,26) returns empty string instead i.e. "450 x 650". I have no idea what it can be...
regards
U¿ytkownik "Joe Fawcett" <joefawcett@xxxxxx> napisa³ w wiadomo¶ci news:uyKV9atrJHA.4592@xxxxxx
> For example:
> Dim item
>> Hi,
>> End With
>> End If
>> Set FSO = Nothing
>> regards
R
Richard Mueller [MVP]
news:gqii98$ne8$1@xxxxxx
regards
Uzytkownik "Joe Fawcett" <joefawcett@xxxxxx> napisal w wiadomosci
> For example:
> Dim item
>> Hi,
>> End With
>> End If
>> Set FSO = Nothing
>> idea
>> regards
I also get an empty string when I use GetDetailsOf to retrieve "Dimensions"
(index 26). I tried several files(*.jpg, *.bmp, and others). I don't know
why.
Richard Mueller
MVP Directory Services
Hilltop Lab - http://www.rlmueller.net
G
God Itself
pls check this:
there is solution to add a DWORD to shell extensions, but it doesn't work in my case.
Empty string may be also result of windows update no 908531
anyway pls paste code from my first post to VBA in excel and call this function to receive dimensions. This is only a way to check whether GetDetailsOf work proprietly.
i hove you use windows XP.. (,26) returns dimensions only in this windows!
Now, i'm at work and this function works fine, but at home i have problem with this!
regards
U¿ytkownik "Richard Mueller [MVP]" <rlmueller-nospam@xxxxxx> napisa³ w wiadomo¶ci news:%23bSlVNurJHA.4684@xxxxxx
> Hi,
why.
R
"Richard Mueller [MVP]" <rlmueller-nospam@xxxxxx> wrote in
message news:%23bSlVNurJHA.4684@xxxxxx
> Hi,
> regards
> wiadomosci news:uyKV9atrJHA.4592@xxxxxx
>> For example:
>> Dim item
>>> Hi,
>>> End With
>>> End If
>>> Set FSO = Nothing
>>> idea
>>> regards
> "Dimensions" (index 26). I tried several files(*.jpg, *.bmp, and others).
> I don't know why.
> Richard Mueller
If find the code works on Windows Server 2003 and XP, but not on Vista. Also
not on Windows 2000.
Richard Mueller
G
God Itself
U¿ytkownik "Richard Mueller [MVP]" <rlmueller-nospam@xxxxxx> napisa³ w wiadomo¶ci news:Ofic5lurJHA.1504@xxxxxx
you're right - should work on XP but it does not on my XP. do not know why...
