GetStringValue silently fails
J
I have a VBScript (see below) that uses GetStringValue to read two
values from the local registry. Both of these values are REG_SZ and
their value is "" (empty string). If I run a single instance of the
script, I *usually* get the correct output:
> cscript //nologo scan.vbs
printSeparatorFile=, typeName=String, rval=0, err=0
System.EnterpriseServices.Thunk.dll=, typeName=String, rval=0, err=0
But every once in a while, the value is reported to be a sequence of 3
unprintable bytes even though the call to GetStringValue returns 0 and
Err.Number is 0. In other words, the call silently fails with a
corrupt value.
printSeparatorFile=FFE869, typeName=String, rval=0, err=0
System.EnterpriseServices.Thunk.dll=FFE869, typeName=String, rval=0,
err=0
I can cause this to happen almost immediately by calling the script
from a batch file, and running two instances of the batch file (see
below) concurrently. Once in this state, it usually stays there until
I restart the WMI service. Though sometimes it seems to clear up on
its own.
I have only seen this problem with some registry values of type REG_SZ
whose value is "".
I have also run regmon 7.03 (sysinternals) to see if other processes
are accessing these registry keys & values, but it only reports
wmiprvse.exe. Interestingly, regmon shows that QueryValue returns the
correct value "", in other words, WMI is receiving the correct value,
but there is a disconnect between WMI and my VBScript.
10.14105988 wmiprvse.exe:3728 OpenKey HKLM\SOFTWARE\Microsoft\Ole
\NONREDIST SUCCESS Access: 0x1
10.14108276 wmiprvse.exe:3728 QueryValue HKLM\SOFTWARE\Microsoft\Ole
\NONREDIST\System.EnterpriseServices.Thunk.dll SUCCESS ""
10.14109898 wmiprvse.exe:3728 QueryValue HKLM\SOFTWARE\Microsoft\Ole
10.14112854 wmiprvse.exe:3728 QueryKey HKLM\SOFTWARE\Microsoft\Ole
\NONREDIST ACCESS VIOLATION
10.14114475 wmiprvse.exe:3728 CloseKey HKLM\SOFTWARE\Microsoft\Ole
\NONREDIST SUCCESS
I'm running on XP SP2. I've tried rebooting, but I get the same
result.
Any suggestions?
TIA,
Josh
Batch File
FOR /L %%G IN (1,1,1000) DO cscript //nologo scan.vbs
scan.vbs
Const HKEY_LOCAL_MACHINE = &H80000002
Set objReg=GetObject("winmgmts:{impersonationLevel=impersonate}!\\.
\root\default:StdRegProv")
If Err.Number <> 0 Then
WScript.Echo "Failed to connect"
WScript.Quit 1
End If
GetValue HKEY_LOCAL_MACHINE, "SOFTWARE\Microsoft\Windows NT
\CurrentVersion\Print\Printers\Dell Laser Printer M5200\DsSpooler",
"printSeparatorFile"
GetValue HKEY_LOCAL_MACHINE, "SOFTWARE\Microsoft\Ole\NONREDIST",
"System.EnterpriseServices.Thunk.dll"
WScript.Quit 0
Function GetValue(hive, key, name)
Dim value
Dim strValue
rval = objReg.GetStringValue(hive, key, name, value)
num = Err.Number
strValue = ToHex(Trim(value))
WScript.Echo " " & name & "=" & strValue & ", typeName=" & TypeName
(value) & ", rval=" & CStr(rval) & ", err=" & CStr(num)
End Function
Function ToHex( strLine )
iLen = Len(strLine)
strEscaped = ""
If ( iLen > 0 ) Then
For i = 1 To iLen
s = Mid(strLine, i, 1)
h = Hex(AscW(s))
If Len(h) = 1 Then
strEscaped = strEscaped & "0"
End If
strEscaped = strEscaped & h
Next
End If
ToHex = strEscaped
End Function
P
Pegasus [MVP]
"Josh" <josh.nw@xxxxxx> wrote in message
news:e10785cf-0532-4ab3-b9c9-df9500ac26c0@xxxxxx
> corrupt value.
> err=0
> its own.
> whose value is "".
> \NONREDIST SUCCESS
> result.
> Any suggestions?
> TIA,
> Josh
> Batch File
> scan.vbs
> WScript.Quit 1
> End If
> WScript.Quit 0
> Dim value
> Dim strValue
> num = Err.Number
> End Function
> iLen = Len(strLine)
> strEscaped = ""
> For i = 1 To iLen
> h = Hex(AscW(s))
> If Len(h) = 1 Then
> End If
> Next
> End If
> ToHex = strEscaped
> End Function
I was unable to duplicate your observation. On the other hand here are some
general remarks:
- While WMI is a wonderful thing, it is also quite slow. You could more than
double the speed of your code if you used the RegRead method of the
WScript.Shell object.
- There is little point in having statements such as "num = Err.Number" in
isolation. If you want your program to continue on an error condition then
you must precede the above statement with an "on error resume next". If you
don't then the program will terminate immediately.
- Your function "GetValue" is not really a function, it is a subroutine. To
avoid confusion, I would call it a sub.
- I would check if RegRead successfully reads a registry value.
Below is your code modified for the RegRead method. Is it subject to the
same problem?
Dim oWshShell
Set oWshShell = WScript.CreateObject("WScript.Shell")
GetValue "HKLM\SOFTWARE\Microsoft\Windows
NT\CurrentVersion\Print\Printers\Dell Laser Printer M5200\DsSpooler\",
GetValue "HKLM\SOFTWARE\Microsoft\Ole\NONREDIST\",
Sub GetValue(value, name)
Dim strValue
On Error Resume Next
ValueData = oWshShell.RegRead(value & name)
num = Err.Number
If Not IsEmpty(ValueData) Then
strValue = ToHex(Trim(ValueData))
TypeName(ValueData) & ", rval=" & CStr(rval) & ", err=" & CStr(num)
End If
On Error Goto 0
End Sub
iLen = Len(strLine)
strEscaped = ""
For i = 1 To iLen
h = Hex(AscW(s))
If Len(h) = 1 Then strEscaped = strEscaped & "0"
Next
End If
ToHex = strEscaped
End Function
