Ghost User Account
T
Theodore Danger
After recently recieving my computer from the manufacturer for repairs, I
found that they had wiped my harddrive as part of the process and then when
they reinstalled everything they created a user account called TEST. Since
it was the only account I just used it when I got it back and started moving
all my files back in. This is where I ran into my problem. I changed the
name of the user account from TEST to Tuna, which is what it was named
before. But I've found that it didn't change everything completely. In the
start menu it says "Tuna" and when I clicked on it, it takes me to the folder
with the documents, music, pictures, etc. And even in the address bar it
said Tuna. However, under C:\Users, there is no Tuna folder, but there is a
TEST folder. In the TEST folder I find all the same files and stuff from the
Tuna folder. When I ping the accounts in the cmd window, I get normal
results from Tuna but it can't find TEST. And when I try to run some
programs such as Matlab, it gives me errors saying that it's looking for
something in TEST and not finding it and other erros to that nature. So it
appears that I have a little of both accounts in one. The question is how do
I fix it.
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
I fix it.
Hi Theodore,
You still only have just the one "C:\Users\TEST" account, but with "Tuna" as a partial rename from "User Accounts" that can cause the problems you are getting. You will need to go back and rename the account back to "TEST" to stop the errors. The "C:\Users\user name" folder can not be renamed. Instead, a new user account must be created first, then delete the old "TEST" account from within the new one.
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
