Global vars in different build scenarios.
A
Adrian
We have a solution where one project contains a set of business rules. We
use the rules in a web application and they're integrated into the main web
project. Any global varaibles for the user are stored on the web session,
and that all works fine.
Now the fun part, we now have to be able to call these business rules from
an old powerbuilder app, where a web server isn't available, so have to use
a com interface layer to call the business rules. The problem is that we
need the com class to initialise some variables and make them available to
the rules class. I know there's not a session object, but how do you go
about coding for the two very different scenarios that the business object
will be living in?
Cheers
Adrian
J
Jeroen Mostert
> will be living in?
I don't know exactly who said it, but it's a truism that there's no problem
in computing that can't be solved by adding an extra layer.
Create a new assembly and within it define a UserGlobals class to hold the
globals you need. Give it a static factory method to return the globals for
a particular user. The business object should use that method only to get at
the globals, and the only thing that's different is the way you
create/initialize these instances. You can check HttpContext.Current to see
if you're running in the context of a website (you can reference System.Web
from any .NET assembly, it doesn't need to be a website project). If so,
retrieve settings from the session, if not, get them some other way.
J.
A
Adrian
Aha ok thanks Jeroen
"Jeroen Mostert" <jmostert@xxxxxx> wrote in message
news:48ecf63d$0$189$e4fe514c@xxxxxx
>> We use the rules in a web application and they're integrated into the
>> main web project. Any global varaibles for the user are stored on the
>> web session, and that all works fine.
>> from an old powerbuilder app, where a web server isn't available, so have
>> to use a com interface layer to call the business rules. The problem is
>> that we need the com class to initialise some variables and make them
>> available to the rules class. I know there's not a session object, but
>> how do you go about coding for the two very different scenarios that the
>> business object will be living in?
> problem in computing that can't be solved by adding an extra layer.
> for a particular user. The business object should use that method only to
> get at the globals, and the only thing that's different is the way you
> see if you're running in the context of a website (you can reference
> System.Web from any .NET assembly, it doesn't need to be a website
> project). If so, retrieve settings from the session, if not, get them some
> other way.
> J.
