good vista for me ?
S
Selds
I am a user that likes to upgrade components over time. I currently have an
X2 cpu and will not upgrade till fall for something better, but I plan to
upgrade my video card in the next 6 months to a dx10 compatible one.
I am currently using winxp pro. I am not sure what are the benefits of media
center as I never used XP MCE. I am using a wireless network, sharing files
and stuff. Going 32 or 64 bits ... I have no idea what is better, I would
guess 64 is better and the newest but I have heard scary stories about XP64.
I never used a computer to access mine over the Internet and don't plant to
do it anytime soon. I mostly play Games, watch movies and not too much music.
That kind of things.
Thank you.
P
philo
an
media
files
XP64.
to
music.
Check out your components and see if you can get 64bit drivers for all of
them...
If so...I'd definatly go with XP_64 rather than Vista.
If you are not sure you can get 64bit drivers for all your H/W...just stick
with XP_32.
S
Selds
What vista would be the best ?
> an
> media
> files
> XP64.
> to
> music.
> them...
> with XP_32.
R
Rick Rogers
Based on what you've listed, I say Home Premium would be sufficient. You
can't upgrade from Pro (that'd require Business or Ultimate), but you can do
a custom install and use the Easy Transfer feature.
As to 32 vs 64, go with 32 unless you have some specific need for a feature
of 64-bit like > 4GB of installed memory. Presently, 32 is more compatible
with available hardware, though I suspect this will change in the coming
years.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
"Selds" <Selds@discussions.microsoft.com> wrote in message
news:E1CC38A7-08C8-4A18-9038-D31B3A6B8C59@microsoft.com...
> Hi,
> an
> media
> files
> XP64.
> to
> music.
> Thank you.
