Grey Toolbar at top of desktop
dawn1872
1
Hi guys, I have no idea how I managed it but the grey navigation bar at the top of my desktop has disappeared! I have no idea how to get it back, does any one know???
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
Hello Dawn, and welcome to Vista Forums.
If you mean the taskbar, then you might check to see if you have autohide turned on for it by mistake. Does it reappear if you move the mouse pointer over where it use to be?
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
stoneys-nutz
Gamerholic
2,685
Location
Wale's
Hello dawn1872,
This is a third party tool bar, do you know the name of it ?, if you do run a search and it will find it, you can then re-install.
If that does not work, you can try a system restore, to a time when the bar was there.
Hope this helps, good luck and post your results.
    Self Build
    QX9650 (black box) 3.0GHz@3.9GHz
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    300 Gig Maxtor, (External)
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
