Grouping and sorting with CollectionViewSource inside the Nov CTP?
P
Philippe Lavoie
Hi
I'm trying to get grouping and sorting working with the Nov CTP and I
can't find any up-to-date documentation on that class. Can someone point
me to a working sample?
Many thanks
Phil
T
Tina Tam [MSFT]
Hi Philippe,
If you have the Nov CTP SDK documentation, you should be able to see an
example on the CollectionViewSource class page (with a link to a
CollectionViewSource sample), or is that not what you're looking for?
Here's a snippet from that example:
<Window.Resources>
<src:Places x:Key="places"/>
<CollectionViewSource Source="{StaticResource places}" x:Key="cvs">
<CollectionViewSource.SortDescriptions>
<scm:SortDescription PropertyName="CityName"/>
</CollectionViewSource.SortDescriptions>
<CollectionViewSource.GroupDescriptions>
<dat:PropertyGroupDescription PropertyName="State"/>
</CollectionViewSource.GroupDescriptions>
</CollectionViewSource>
</Window.Resources>
<DockPanel>
<ListBox ItemsSource="{Binding Source={StaticResource cvs}}"
DisplayMemberPath="CityName" Name="lb">
<ListBox.GroupStyle>
<x:Static Member="GroupStyle.Default"/>
</ListBox.GroupStyle>
</ListBox>
</DockPanel>Thanks,
Tina
"Philippe Lavoie" <philippe.lavoie@cactus.ca> wrote in message
news:%23xOBSbNAGHA.3936@TK2MSFTNGP12.phx.gbl...
> Hi
> Many thanks
> Phil
P
Philippe Lavoie
Re: Grouping and sorting with CollectionViewSource inside the NovCTP?
Thanks Tina
I was so sure that the samples were not working that I didn't even
bother looking there :) Instead I looked on the web and none of the
information works with the Nov CTP (even MSDN which is kind of strange).
I will look there next time :)
Phil
Tina Tam [MSFT] wrote:
> Hi Philippe,
> <Window.Resources>
> </Window.Resources>
> <DockPanel>
> </ListBox>
> </DockPanel>Thanks,
> Tina
T
Tina Tam [MSFT]
Ah, I see. Just FYI, MSDN has a different refresh schedule. The content
there is only refreshed when there is a major milestone (such as a beta, but
not a CTP). Therefore the Nov CTP SDK docs are more up-to-date than the
online docs.
Also, the samples that don't compile in the Nov version of the SDK are
documented here:
http://download.microsoft.com/downl...5724dc889ed6/Microsoft Windows SDK Readme.htm
Hope that helps,
Tina
news:uWtu5iYAGHA.2036@TK2MSFTNGP14.phx.gbl...
> Thanks Tina
> I was so sure that the samples were not working that I didn't even bother
> looking there :) Instead I looked on the web and none of the information
> Phil
>> Hi Philippe,
>> <Window.Resources>
>> </Window.Resources>
>> <DockPanel>
>> </ListBox>
>> </DockPanel>Thanks,
>> Tina
