Guest reboots when Host reboots?
T
Theresa
Hello,
I was wondering if there was anyway to have a VM automatically restart after
the Host machine restarts (i.e. if the host machine reboots, I would like the
guest machine to restart as well). I noticed there were some options in
Virtual Server, but I havnt seen anyting for Virtual PC. Thanks!
M
Mark Rae [MVP]
"Theresa" <Theresa@xxxxxx> wrote in message
news:E6431653-D085-405B-A3CF-124B745D2E09@xxxxxx
> after
> the
Place a shortcut to the VM's VMC file in the host's Startup folder.
Mark Rae
ASP.NET MVP
http://www.markrae.net
B
Bo Berglund
On Fri, 5 Sep 2008 22:15:30 +0100, "Mark Rae [MVP]"
>> after
>> the
Works only when someone logs in to the newly rebooted Windows PC....
But if you want to boot up the guest when the host boots up then you
need a service system like Virtual Server, it will be independent of
any user logging on to the host PC.
VPC2007 is not designed for this, its target is desktop (workstation)
virtualization, whereas VS2005 aims primarily for server
virtualization.
Bo Berglund (Sweden)
M
Mark Rae [MVP]
"Bo Berglund" <boberglund@xxxxxx> wrote in message
news:t4d3c4lhm9345058emngp2c8920q465pss@xxxxxx
Of course. I assumed (maybe incorrectly) that that's what the OP meant...
Mark Rae
ASP.NET MVP
T
Tim Walsh
You can use the Task Scheduler to accomplish this. Basically you'll need to
create a command file on the host machine. To do this open notepad and type
the following into the open window:
"C:\Program Files\Microsoft Virtual PC\Virtual PC.exe" -pc "DOS
6.22" -singlepc -launch
The quotes are necessary due to the spaces in my path and naming convention.
Change the path and pc name to match your own path and VM name. Once you
have done this save the file to the local hard drive, I use a folder
directly off the root of the C: drive called Tasks to save these types of
files in. Name it something that will make sense to you later, like "Launch
VM DOS6_22.cmd". I'm assuming you already know that by giving it a .cmd
extension the file becomes a command file and can be run by double clicking
it. TEST the file by double clicking on it and verifying the VPC starts the
VM for you. If it doesn't edit the file and verify your path and name are
correct. If the file doesn't run, verify that the file extension is correct,
Microsoft did us no favors when they decided to hide the file extensions
from us, and notepad might have added a .txt to the end of the file for you.
Once you have your command file working properly, open your control panel
and select the Scheduled Tasks icon. Be patient while it populates the list
for you. Select the Browse button and then go to where you saved the file
above and select it. From the next window select the "When my computer
starts" option. You can also give the job a name at this point, but it will
usually use the file name and should already make sense to you. On the next
window you'll need to decide which credentials to use to start the job, it's
best to use some that don't require the password to change periodically, and
even better would be to create a local account or network account
specifically for scheduled tasks to use, and then restrict it to the
appropriate permissions on the box.
Finish the wizard and test your job by right clicking on the job and
selecting run. It should start. If you used a different account to run the
job under then you are currently logged in as the job will start, but you
won't be able to see it and you won't be able to launch Virtual PC in your
session since it's already running on the host machine. Only one instance of
virtual machine can run on a host machine at a time.
> Hello,
> after
> the
T
Tim Walsh
I probably should mention that if you use this approach there are some
serious limitations depending upon what your doing.
1) With VPC running you won't be able to run a second instance of it on the
machine, so you won't be able to modify or create new VMs unless you
shutdown the first running instance of VPC using the Task Manager.
2) I've never been able to open the VPC console to get to the running VMs,
so you need to ensure your VMs are configured for remote access, eg Remote
Desktop is enabled on a windows machine. I'm not sure what you'd use on a
Linux machine.
3) The credentials you use to run VPC under need to have access to the VM
files, and the VM needs to have been setup under those credentials before
you start it using this method. I believe there is a command line switch
that you can use to do the registration the first time, but haven't used it
before. If you don't set the VM up first you'll find that VPC is running,
but is waiting for you to configure the VM.
4) I've never tried it, but in theory you could use multiple VMs by just
launching the VPC directly with the auto start feature enabled.
5) When you reboot the host you'll want the VMs to respond appropriately,
shutdown or turnoff or save state, make sure you've configured them
appropriately.
"Tim Walsh" <tmwalsh@xxxxxx> wrote in message
news:eiTOAoAEJHA.5004@xxxxxx
> to create a command file on the host machine. To do this open notepad and
> type the following into the open window:
> convention. Change the path and pc name to match your own path and VM
> name. Once you have done this save the file to the local hard drive, I use
> a folder directly off the root of the C: drive called Tasks to save these
> types of files in. Name it something that will make sense to you later,
> like "Launch VM DOS6_22.cmd". I'm assuming you already know that by giving
> it a .cmd extension the file becomes a command file and can be run by
> double clicking it. TEST the file by double clicking on it and verifying
> the VPC starts the VM for you. If it doesn't edit the file and verify your
> path and name are correct. If the file doesn't run, verify that the file
> extension is correct, Microsoft did us no favors when they decided to hide
> the file extensions from us, and notepad might have added a .txt to the
> list for you. Select the Browse button and then go to where you saved the
> file above and select it. From the next window select the "When my
> computer starts" option. You can also give the job a name at this point,
> but it will usually use the file name and should already make sense to
> you. On the next window you'll need to decide which credentials to use to
> start the job, it's best to use some that don't require the password to
> change periodically, and even better would be to create a local account or
> network account specifically for scheduled tasks to use, and then restrict
> it to the appropriate permissions on the box.
> of virtual machine can run on a host machine at a time.
>> Hello,
>> after
>> the
