hard drive continues to run for exteneded time
I have an HP 6030 computer that for the last two months seems to run the
hard drive even though there is nothing that is supposed to use the drive.
This is the first computer that has done this and I have owned many home
computers since 1984. When I check performance from the Task Manager, There
are a series of spicks up to 4% every minute of so. The hard drive light is
going constantly during this time.
Sometimes the light goes out and stays out even though I have not done
anything on the computer.
It comes with the standard software that HP installs plus a program to keep
track of my DVDs that I run only once a day.
Is there some program that HP installs that should cause this lengthy
running time.
Just now, after 40 minutes it finally turned off - and I have my Windows
Mail program open and nothing else.
That is the way it works all the time now. Is there something that needs to
be reset?
Thanks.
Brink
Staff member
mvp
32,205
Location
Oklahoma, USA
running time.
be reset?
Thanks.
Hi PAB,
It could be the Index running in the background updating itself. You can test to see by temporarily disabling it.
http://www.vistax64.com/tutorials/69564-index-enable-disable.html
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
S
Steve Thackery
There are lots of things in Vista that exercise the hard disk even when you
are not using your computer.
1/ Indexing is one, as brink pointed out.
2/ Every so often Vista shuffles some files around to speed up the startup
time.
3/ Once a week Vista kicks off a defrag of the hard disk, which runs in the
background, backing off when you are using your computer (and thus running
mostly when you are not).
4/ Every so often Vista preloads files into memory in anticipation that you
will want to use them (based on your usage patterns to date) - which speeds
up the response times.
This is all good stuff and the sort of thing any good OS should be doing. I
recommend you ignore it - it doesn't mean anything is wrong.
SteveT
Glymps
1
I have had the same problem with my HD running for long periods of time. I too have read over and over on several threads about indexing and windows search.
One big, probably the biggest, contributor to my HD running was the Desktop Windows Manager (dwm.exe). From what I read the DWM continuously creates thumbnails of the pop ups on the task bar. Once I disabled this option the HD activity stopped.
I went further to review my services and my msconfig to review which services were running automatically and started at start up.
This path worked for me and for now the HD is quiet as a mouse.
Oh, I will point out that with the indexing off I have seen some delays in the search, which is to be expected. For the most part I know where things are on my PC.
I hope this helps.
