hard drive problem
T
im haven a problem with my second hard drive the problem is it dont show up
on vista. i had window min, both drive was working fine. i format both drive
only one work but the other dont any suggestions?
T
i was running on windows Millennium and both hard drive was working
fine...yeah i checked, its not in BIOS. I did almost everything but then when
i tryed it in another computer the drive work fine but the outer computer is
running on windows xp. I format the drive in ms dos.... D: format
> I don't know what "window min" means, but:
> 1. Check if the drive shows in the BIOS.
> Accessing the BIOS
> http://michaelstevenstech.com/bios_manufacturer.htm
> http://www.uktsupport.co.uk/reference/biosp.htm
> http://www.computerhope.com/issues/ch000235.htm
> 2. If it doesn't show, check your jumpering (assuming an IDE drive).
> Find jumpering details for the drive on the drive mftr.'s tech support
> website. Also check your cabling.
> 3. How did you format the drive? Does it show up in Disk Management
> (Administrative Tools in Control Panel)?
> Malke
> Elephant Boy Computers
> www.elephantboycomputers.com
> "Don't Panic!"
> MS-MVP Windows - Shell/User
M
Malke
If the drive works in another computer, then you know the drive is still
good. Therefore the problem must lie in the way you've installed it in
the upgraded computer. As I said, check jumpering - on *both* drives
since some drives require a different jumpering for Master-with-slave
than they do for just Master/Single. Also you might try a different IDE
cable, making sure it is 80-pin and not the old 40-pin.
Other than that, you might consider having someone knowledgeable take a
look since it will be rather difficult to diagnose what you are doing
wrong without actually seeing the computer.
Malke
"Don't Panic!"
T
thanks for the input!!! i will sure do that this weekend
> Malke
> "Don't Panic!"
