Hard drive write protected
S
Sashi
Hi all,
On my vista box, my C:\ drive is protected against writes and I need
to manually authorize each write.
Needless to say, this is turning out into a major pain in the ass as I
can't run any programs which need write access.
Is this an inbuilt Vista feature? How do I disable this?
Thanks,
Sashi
M
Mark L. Ferguson
The NTFS file system allow you to change access right if you 'run as admin'.
You receive an error message when you try to save a file to a hard disk
drive or to a flash device in Windows Vista :
http://support.microsoft.com/kb/931277/en-us
Was this helpful? Then click the Ratings button. Voting helps the web
interface.
http://www.microsoft.com/wn3/locales/help/help_en-us.htm#RateAPost
Mark L. Ferguson
"Sashi" <smalladi@xxxxxx> wrote in message
news:c6057bd3-69b0-4bdb-b476-989dc62cbee6@xxxxxx
> Hi all,
> Thanks,
> Sashi
You might try this. Open an admin command prompt. Type [cd\] Press Enter.
Type [attrib -r] Press Enter.
> Hi all,
> Thanks,
> Sashi
