Solved Hardware Upgrade
Tnuh555
Just another lunatic
Power User
76
Hello!
I was looking to upgrade some of my computer's hardware for Christmas, but am unsure where to start. I was planning on a video card, and the video card will probabaly need a better power supply to accommodate it's power needs.
Here is a link to the specs of the computer:
HP Pavilion a6130n Desktop PC - Product Specifications
I hate the Integrated video card, It really falls short of what the sales rep said 3 years ago. Tried playing Quake 4 when I got it and the results were not great.
I'm asking you guys what parts that you think I should get/ ask for. I would try to look for myself, but I am very busy with school.
All help is appreciated!
If you need any info, let me know and I will try to find it.
The installed PSU is 250 Watts.
Operating Systems: Windows 7 Ultimate 32 bit, Windows Vista Home Premium 64 bit. (Dual boot)
    Samsung R60 Plus
    Intel Core 2 Duo T7250 @ 2.00 Ghz
    2 GB DDR2 RAM
    ATI Radeon Xpress 1200 series
    Realtek Hi-def Audio
    Mobile PC Display
    Fujitsu 120 GB SATA drive
    100 mb/s
    South Korean model,
    Shipped from an english teacher half way across the world =P
richc46
Staff member
20,105
Location
Fairfield County, CT
Welcome
The one upgrade that appears at first glance is memory. With a 64 bit OS and a 32 bit Ultimate Seven, I would suggest at least 4 gb of ram. It will imporve the 64 bit. OS. I think that 6 would be a bit too much, unless you are into resource hungry games,etc.Dont mix and match. Discard what you have. Many may disagree, but I think that my way is best.
I will research a bit early tomorrow to come up with other upgrades, such as video card etc.
Lorien
Account Suspended
2,212
Location
Laytonsville, Maryland, USA
Hi Tnuh555,
Here's an article on how to replace/add a video hard in an HP desktop: Installing or Replacing a Video Card - HP technical support (United Kingdom - English).
You can use one that fits a PCI, PCI Express x16, or PCI Express x1 slot (you have one of each available according to the specs). Note several cards require two slots (of the same type), so you'll need to exclude those.
The card will tell you if you need a more powerful power supply - and it is VERY likely given that you currently have only 250W. Most cards want 400-500W.
There are many choices of video cards, but for your system I recommend the following: Every PC needs good graphics.. Note that it needs a minimum of 300W power supply, so you should get at least a 400W (as it's always better to have more power than speciified). I would also get the 1GB memory option so it will definitely support your games.
I believe that plus the memory upgrade Richard already recommended should take care of your needs for the time being.
I hope this helps.
Good luck!
    1920 x 1200 pixels
    Dell AIO Printer A940
    6TO4 Adapter
    Microsoft ISATAP Adapter
    Router Linksys / WRT54G -01
Tnuh555
Power User
76
Alright, I was checking out the link for the Nvidia card that Lorien had sent, but this raises more questions. I assume the power supply would be easy to replace, It would include general directions. As for the graphics card, I seem to be worried about if it will seat properly. My motherboard is by ECS (Elite group). I went there because I did not notice anything for ECS mobos on the Nivida website.
The thing that gets me is that the motherboard is attached to the left side of the PC, the right panel comes off. When I look inside, the slots look backwards, that the little notch in the graphics card goes closer to the end with the ports, but the slot withing my pc has the little notch closer to the end with no ports. It's hard for me to explain, but you may get what I mean. I will look again, but I just figured Id put that out there. I will update with my findings soon.
My RAM seems optimal at 3 GB, if anything is still running slow, I will upgrade the RAM.
For now, the main concern is getting a dedicated video card, Integrated graphics are a joke.
I do thank you for your recommendation, I may just go with that video card. The prices really looked cheap enough. :)
    Samsung R60 Plus
    2 GB DDR2 RAM
    Mobile PC Display
    100 mb/s
    South Korean model,
richc46
Staff member
20,105
Location
I would look into that RAM, too. It will improve the perfrormance of the 64 bit.
If you want a good graphics card, etc. you may be into resource hungry games.
Press Alt Cntr Delete and see what is using most of the memory. You may be able to remove it from start up to improve performance, even with the current RAM
Best of luck to you
Come back with any further questions or problems.
Tnuh555
Power User
76
Alright.
Time to open the tower :).
    Samsung R60 Plus
    2 GB DDR2 RAM
    Mobile PC Display
    100 mb/s
    South Korean model,
richc46
Staff member
20,105
Location
Type :alt cntrl delete, and then task manager. Go to processs see what the big memory users are. May be able to disable and have better performance.
Tnuh555
Power User
76
#8
I know it's the graphics card. I tried that many times before and it seldom works. I want to play games like Team fortress 2 and Half life 2, with that, I need a graphics card.
As for looking in the pc, there are two open slots, one is really small. It is white in color. The other slot looks more like a PCI-E slot, it's a longish slot, black in color, with a lever to hold it in. As for the slots having the notch in the wrong spot, you can ignore that. I guess I was looking at the old PCI slots at the time. I really do appreciate the help. Now I just need to find a decent graphics card.
Should I be worried about who the motherboard manufacturer is though? I don't want to get the thing on Christmas morning and have to send it back.
    Samsung R60 Plus
    2 GB DDR2 RAM
    Mobile PC Display
    100 mb/s
    South Korean model,
Tnuh555
Power User
76
#9
Mabye a can of air would be beneficial too, it's quite dusty in there!
    Samsung R60 Plus
    2 GB DDR2 RAM
    Mobile PC Display
    100 mb/s
    South Korean model,
Lorien
Account Suspended
2,212
Location
#10
As long as you have a working PCI-E slot available and the system is running Vista, I believe you will be fine in terms of the motherboard. It is remotely possible it won't be compatible, but I sincerely doubt it. I will try to check further to see if I can get some type of confirmation - but it is not going to be easy to find.
    1920 x 1200 pixels
    6TO4 Adapter
Tnuh555
Power User
76
#11
Well, as far as the PSU, it would seem as any ATX PSU would fit, I read this on another forum, and the images for them look similar as well. Ill probably go with a 400W supply. Any newer games that come out I might just buy for the PS3.
    Samsung R60 Plus
    2 GB DDR2 RAM
    Mobile PC Display
    100 mb/s
    South Korean model,
Tnuh555
Power User
76
#12
Ok, I got the PSU figured out. As for the graphics cards, I seem to have figured them out. The question is which one to buy now.
    Samsung R60 Plus
    2 GB DDR2 RAM
    Mobile PC Display
    100 mb/s
    South Korean model,
bruce2
Vista Pro
618
#13
Hi Tnuh555,
I believe in your earlier posts mentioned that the PCI X 16 slot seems backward is actually a wrong slot you were looking at. The black one is the correct one. So it is compatible to any mainstream GPUs. Here is your MB: ECS HP MCP61PM-HM Nettle3-GL8E AM2+ GeForce 6150SE Motherboard
As far as which GPU to get, I would get either the cheapest or next to the cheapest ATI or nVidia with 1GB of RAM such as this: Newegg.com - ATI 100-505606 FirePro V4800 1GB GDDR5 PCI Express 2.0 x16 Workstation Video Card Anything better wouldn't do much good cause your CPU would be the bottleneck.
I would get a at least 500W PSU on the safe side; it only costs a tiny bit more.
As suggested as in the previous comment, I would definitely fill up all four memory slots available.
At last, if you are still using the monitor listed in "specs", you might think of a small upgrade with something like this or better: Newegg.com - SAMSUNG B2030 Glossy Black 20" 5ms Widescreen LCD Monitor 250 cd/m2 DC 50000:1(1000:1) I think it is very important to have good monitor because it is the part of the computer you are looking at the most. You would enjoy looking at it more and also good for your eyes. In any chance if you switch out your computer, you can keep the monitor.
Please keep us update on how things going. Good luck and enjoy!
Bruce
    E6850
    EVGA 122-CK-NF67-A1 680i
    4 x OCZ Platinum 1GB
    ATI Radeon HD 5850 1GB
    SB X-Fi X Audio
    Samsung 23" 5MS
    2048 x 1152
    Seasonic 600W M12
    CM Centurion 5
    air
    100Mbps
Tnuh555
Power User
76
#14
Yea, I guess I didn't make it really clear that I was looking at the wrong slot. It was over a year ago that I really looked at it, and today I just opened it and posted whatever was in there. Didn't look at the notches or w/e. Anyway, I don't think I have the monitor in the specs, I got a 22 inch monitor as a bundle. The graphics card looks good, but I may be able to find something similar for less somewhere else. Thanks for the input!
    Samsung R60 Plus
    2 GB DDR2 RAM
    Mobile PC Display
    100 mb/s
    South Korean model,
fieseler
543
Location
Leicester
#15
you might want to look at the gt240, anything higher and i dont think the ventilation in your case would be adequate (assuming you havent swapped the case out already)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130531&cm_re=evga_240-_-14-130-531-_-Product
If your looking for something that has directx11 support, the gt430 is a littler greater performance-wise to the 210 that Lorien linked to, but the 240 is still the better card.
Newegg.com - EVGA SuperClocked 01G-P3-1435-LR GeForce GT 430 (Fermi) 1GB 128-bit DDR3 PCI Express 2.0 x16 HDCP Ready Low Profile Video Card
EDIT:
I would also grab a 500w psu incase you want to add anything at a later date. Otherwise you'll only end up buying another one next year when you want to upgrade again ;)
    §ĮŁΣNŦ Д$$Д$$ĮN
    Xeon X3360
    P5W64 WS Pro
    EVGA Geforce GTX470 SC+
    Samsung T200
    WD 1TB RE3
    Thermaltake Toughower 750w
    NZXT Lexa Silver
    Zalman CNPS10x Extreme
    Razer Deathadder 3500dpi
    Razer Lycosa Mirror
    24Mb/s
Tnuh555
Power User
76
#16
EDIT:
Alright, that graphics card looks like it would do the trick. As for the power supply, I'm unsure about one thing. This may sound stupid, but when you buy a power supply, does it come with all of the power connectors already attached? If they don't, would it be easy to attach them? I am by no means an electrician.
    Samsung R60 Plus
    2 GB DDR2 RAM
    Mobile PC Display
    100 mb/s
    South Korean model,
bruce2
Vista Pro
618
#17
PSUs come in two ways. A regular one as the one you have in your case look like an octopus with every connection you need plus some extra connectors coming out of the unit. The other called detachable which you can attach the cables come with the PSU you need to the PSU so you wouldn't have to worry about tucking the unused one away.
The connectors only fit certain components, so you don't have to worry too much. You might mark or remember where on the MB needs a connector so you wouldn't left something out.
Hope this helps.
Bruce
    E6850
    SB X-Fi X Audio
    Samsung 23" 5MS
    2048 x 1152
    Seasonic 600W M12
    CM Centurion 5
    air
    100Mbps
Tnuh555
Power User
76
#18
Hope this helps.
Bruce
So, let me make sure I am understanding you right. From my understanding, I would need to attach whatever power wires I needed TO the power supply, the power supply will have NO wires attached when I take it out of the box it was shipped in, those will be in a separate container of some sort with the PSU, right? Cant be too hard, as long as I don't need to solder anything I think I will be fine.
Thanks for all the help everyone!
    Samsung R60 Plus
    2 GB DDR2 RAM
    Mobile PC Display
    100 mb/s
    South Korean model,
bruce2
Vista Pro
618
#19
Hope this helps.
Bruce
If any PSU which didn't specify as detachable has all necessary wires coming out of the unit looks like and octopus. Such as this:
Newegg.com - SeaSonic S12II 520 Bronze 520W ATX12V V2.3 / EPS 12V V2.91 80 PLUS BRONZE Certified Active PFC Power Supply
On the other hand, a detachable one would be looking like this one as you will notice there are less cables coming out of the unit. Instead, there are a bunch of souckets: Newegg.com - OCZ ModXStream Pro OCZ500MXSP 500W ATX12V V2.2 / EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC Power Supply compatible with core i7
There are no performance difference between the two type. Only different is that one has less unused cables to tuck away.
    E6850
    SB X-Fi X Audio
    Samsung 23" 5MS
    2048 x 1152
    Seasonic 600W M12
    CM Centurion 5
    air
    100Mbps
Tnuh555
Power User
76
#20
Alright, I know what to get now and how to install it. Thanks for all of the help!
    Samsung R60 Plus
    2 GB DDR2 RAM
    Mobile PC Display
    100 mb/s
    South Korean model,
