HD DVD Question
C
Chris Saunders
Is there a way to play a HD DVD on Vista. I purchased a movie without
realizing that it was in this format (which I know nothing about) and not
only does Media Center not seem to be able to play it but Explorer doesn't
seem to recognize that there is a disk in the DVD player. Sorry for my
ignorance on this subject but can anyone help?
Regards
Chris Saunders
G
Gary Mount
A regular HD DVD drive will also work.
"Martin" <martin@xxxxxx> wrote in message
news:qLSdnQb-Ds82BvLanZ2dnUVZ8sKlnZ2d@xxxxxx
> "Chris Saunders" <evas@xxxxxx> wrote in message
> news:C8662144-9E1F-4EA2-B9C8-24A9909212E7@xxxxxx
>> doesn't seem to recognize that there is a disk in the DVD player. Sorry
>> for my ignorance on this subject but can anyone help?
>> Regards
>> Chris Saunders
> Hi Chris,
> You need a special HD DVD drive to play that type of DVD.
> HTH
> Martin
A
Andrew Rossmann
[This followup was posted to microsoft.public.windows.vista.general and
a copy was sent to the cited author.]
In article <C8662144-9E1F-4EA2-B9C8-24A9909212E7@xxxxxx>,
evas@xxxxxx says...
HD-DVD's usually come in a red-edged case. Blu-Ray come in blue-edged
cases.
To read HD-DVD's, you need an HD-DVD drive. The same goes for Blu-Ray. A
standard DVD drive will not recognize either HD format.
Unless you want to buy a new drive (standalone or computer, both are
$$$$$) and have a powerful enough computer, try and return it. Even
though it is open, hopefully the stores will allow for that. Otherwise,
you have learned a lesson.
If there is a no_junk in my address, please REMOVE it before replying!
All junk mail senders will be prosecuted to the fullest extent of the
law!!
http://home.att.net/~andyross
A
Andre Da Costa[ActiveWin]
Windows Vista has native support for HD DVD disk, as long as you have the
appropriate optical drive installed in your computer.
Andre
Blog: http://adacosta.spaces.live.com
My Vista Quickstart Guide:
http://adacosta.spaces.live.com/blog/cns!E8E5CC039D51E3DB!9709.entry
> Regards
> Chris Saunders
