HDD Replacement Question
My WD5000AAKS-00TAM0 hard drive decided to give up the ghost a couple of nights ago. Seeing as it needs to be replaced, I am having a tough time deciding which model I should replace it with.
Should I find another HDD with the same build as my old one, or get a new model? (Still a Western Digital)
I've had these two in mind: (For a family computer/casual gaming. Keep in mind, some suggestions said as long as the GB storage and RPM matched with the old one, there's no difference)
Western Digital WD Green WDBAAY5000ENC-NRSN 500GB SATA 3.0Gb/s 3.5" Internal Hard Drive
Western Digital WD Blue WD5000AAKX 500GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive
    Gateway GM5472
You want the "Blue" drive. The "green" is a power savings drive, which means it spins slower and shuts off to save power all the time. Great for storage, bad for running windows on.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
Hi megaman306,
SATA 2.0 works with 3.0 Gbit/s. SATA 3.0 works with 6.0 Gbit/s.
In case the motherboard has SATA 3.0 you can install Western Digital WD Blue WD5000AAKX 500GB 7200 RPM 16MB Cache SATA 6.0 Gb/s 3.5" Internal Hard Drive, if not you can install the other one.
You can also install Western Digital WD Blue WD5000AAKX 500GB 7200 RPM 16MB Cache SATA 6.0 Gb/s 3.5"drive in SATA 2.0 port it would with the speed of 3.0 Gbit/s.
For any further questions in future please feel free to contact us.
    AMD FX-4100
    Gigabyte
    4Gb
    ATI 5450
    1600*900
    10Mbps
