Headset microphone
F
Fredrik
I would like to run a software where I'm supposed to use a headset and need
to hear what I'm saying in the microphone in the headphones.
The microphone is working, and so are the headphones, but I can't get the
feedback.
This is easyto solve in XP, but I can't find out how to do it in XP.
M
Mike Hall - MVP
"Fredrik" <Fredrik@xxxxxx> wrote in message
news:DCB2D4F0-2087-45BC-9B41-20A62CF23772@xxxxxx
> feedback.
Control Panel > Sound > Levels tab
Do you see the speaker at the end of the volume scale? unmute it..
Mike Hall - MVP
http://msmvps.com/blogs/mikehall/default.aspx
F
Fredrik
The speaker is unmuted and everything seems to work (I can record and
listen), but I can't get the sound from the mic directly to the earphones.
> > feedback.
> Mike Hall - MVP
C
Colin Barnhorst
Scan this ng for similar issues and their resolution a few weeks ago. I
remember some but not the resolution.
news:081DE8D4-C4CD-444D-8B3E-902D72953C57@xxxxxx
>> >need
>> > the
>> > feedback.
>> Mike Hall - MVP
A
Alejo
Man i heve the same problem. did u figure out how to solve the problem?
> > > feedback.
> > Mike Hall - MVP
jturpin1
1
I have researched this issue elsewhere for the vista OS. I've read that you can go to Control Panel>Sound>Recording tab> right click the main box > show disabled components> (apply and then perhaps restart the system, return to the recording tab) > enable 'mix out' or similar component name.
Others have said this works for them, as for myself, I still do not see any new components to enable when I choose to display the disabled ones. Does anyone have any more ideas beyond this?
