Hello there. Have a seat and I'll tell you a tale of woe and sorrow...
I just built this rig, not quite a week ago:
CPU - e8400 @ 3.6
Cooler - Zalman 9700
GPU - XFX 8800GTS 512 @ stock
RAM - 2x2gb OCZ Reaper DDR2 800 @ 5-5-5-15
MOBO -Asus Maximus Formula (BIOS current @ 0907)
PSU - Corsair TX750
HDD - 2 x Seagate 320gb
Case fans - Plenty
OS - Vista 64 Ultimate
Patience - Wearing thin
Anywho, I installed Vista, and was wowed by the eye candy. I mean, I really love the way this OS looks. Aero is fantasmic! Unfortunately, I haven't been stable since day 1.
I have been getting BSODs daily, usually 3 or 4 times a day. Most of the time, it is a Irql_less_not_equal BSOD. I have gotten some others, but can't remember exactly what they were, but the Irql one is the one that seems to love me.
I have run Memtest completely stable for 1 hour, 2 passes. I have run OCCT for an hour stable. I have run Prime95 stable for an hour. At OC of 3.6, my temps at idle ar 35C, at load I see 47C. Nothing to be worried about there. I have even stopped my OC, and ran at stock - yep, the problems remain.
I have the newest nVidia driver 169.25, and the newest chipset drivers. There isn't much rhyme or reason as to when the BSODs occur... It may be during a browsing session of the internet, or it may happen during an installation of some software. I had a BSOD at shutdown, during a restart once.
I don't know if this is hardware related, and I don't imagine that it is. It just "seems" software or driver related to me. It is quirky, in that software kind of way, know what I mean?
I even tried to set up a dual boot. I already had Vista 64 installed, and tried to install XP on the same drive. (I know how to do this, I have the instructions/ writeup on my comp.) When XP was installing, after about 1 min, while it says 'loading windows' or something like that at the bottom of the screen, I got a BSOD, STOP: 0x0000007B (0xF7BD2524, 0xC00000034, 0x00000000, 0x00000000). I tried to install XP on my other HDD, now this other HDD is brand new, it has only been formatted, nothing has ever been written on it. I got the same STOP message as on the main HDD.
SO... what the heck? Any ideas? If Vista doesn't want to be my pal, fine. But I can't even hangout with my old friend XP anymore, because it refuses to install on either HDD. :eek:
Any ideas?
P.S. The thing that really makes me mad is I have been playing S.T.A.L.K.E.R. on this comp, and it has worked fine. No BSODs during play. I loaded Oblivion on here this evening, and about 30 minutes into the game, bam, I get a message that Oblivion had to shutdown.
HELP ME MR. WIZARD!!!
CPU - e8400 @ 3.6
PSU - Corsair TX750
Case fans - Plenty
Any ideas?
