Help!! cannot use Adobe Flash player with Vista
flconcerns
I have read a lot of forums on here and on other sites (Adobe for one). I have yet to see a resolution. PLEASE HELP! MY IE is closing down too much to bear any more.
I have a Vista 64 bit OS, and I use IE 7 (using the 32bit IE) and I can't use IE without it closing and restarting all the time. From experimenting and reading lots of forums, it is obvious that Adobe Flash Player and Vista just don't work together. It is Vista because I have friends that use other OS and IE 7 and they are not having the problems I have. Whats happening is ... when I am using IE, flash works but all of sudden my IE will close and restart. So clearly using the Flash player as the issue.
And yes, I've tried uninstalling and reinstalling Adobe a few times now.
I have also disabled the adobe flash add-on but most sites now a days want you to have that, so you need it. (and forget playing games on FB, like Farmville or Yoville or Cafe World, it will close down on you).
I've seen forums where (a supposed "google employee") stated that if you download some link from some Japaneese site that will solve the problem. But with today's virus's and malware who would do that?
I've also read that this whole problem has to do with a sound card, or some registration key, or start up items (ie wireless assistant).
There are so many things out there. I just need the bottom line... from Vista please! and my question is... Is there a way to use flash player on your 64 bit system? If not, are we supposed to just wait until Adobe comes out with a compatible version? Or is there a work around?
I've heard that this happens in all internet applications (Firefox, google chrome). So
its not and IE problem. It seems to be clear that this is a Vista 64 bit
OS and Adobe Flash Player issue. PLEASE help! I need flash!
Thank you!
    HP Pavillion dv5-1235dx Entertainment Notebook PC
    high speed
townsbg
~~тσωηsвg~~
    Windows 7 Pro x64
    Mid 2010 iMac
    Quad core 3.2 Ghz Intel I3
    8 gb
    ATI Radeon HD 5670 512 mb ram
    1920x1080 and 1440x900
    1 TB
    N/A
    Windows 2008 R2 Enterprise
    Compaq Presario SR5350F
    Pentium 2.0 gHZ Dual core E2160
    2 gb
    1440 x 900
    300 GB
wither 3
Also, make sure you're downloading the 64 bit version of AFP.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
townsbg
~~тσωηsвg~~
    Windows 7 Pro x64
    Mid 2010 iMac
    8 gb
    1 TB
    N/A
    2 gb
    1440 x 900
    300 GB
Ex_Brit
If you're going through hell, keep going
You should be using IE9 not IE7. I assume this is Vista SP2? Flash only works in 32-bit IE anyway so make that your default.
    Win 7 Ult SP1 + Win 10 Pro all x64
    Alienware ALX x58
    2 x 500gb SATA II
    1 x 1TB SATA II
    1 external eSATA LaCie 3TB
    (Non-RAID)
    Unique
    1gb/s up and down
wither 3
I have adobe flash player 11,1,102,62 loaded on my Vista 64 bit system. I used the 64 bit version.
I'm using IE 8.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Ex_Brit
Ah, according to the Adobe download page:
Flash Player does not support 64-bit versions of Windows XP and Vista. Flash Player 11 now includes support for Windows 7 64-bit.
But according to my 64-bit IE Flash is working OK whilst Shockwave isn't...weird.
    Alienware ALX x58
    2 x 500gb SATA II
    1 x 1TB SATA II
    (Non-RAID)
    Unique
    1gb/s up and down
tom982
٩(͡๏̯͡๏)۶
This thread is dated 12-20-2009, so IE7 was probably the most recent version of IE at that point :)
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    Samsung EVO 128GB SSD
    Seagate Barracuda 2TB 7200rpm
    NZXT Phantom 410
Ex_Brit
Crikey, I never noticed, thanks....!
    Alienware ALX x58
    2 x 500gb SATA II
    1 x 1TB SATA II
    (Non-RAID)
    Unique
    1gb/s up and down
tom982
٩(͡๏̯͡๏)۶
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
wither 3
Take a look at this. If you have IE 64 bit, then, when you download AFP 11, you will get the 64 bit version. It's confusing because it says to install the 32 bit version on Vista 64 bit. However, I downloaded and installed the 64 bit version because I have IE 64 bit.
Flash Player | 64-bit operating systems
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Ex_Brit
It's confusing indeed. Until things are totally sorted out I'll continue using the 32-bit IE.
    Alienware ALX x58
    2 x 500gb SATA II
    1 x 1TB SATA II
    (Non-RAID)
    Unique
    1gb/s up and down
townsbg
~~тσωηsвg~~
Good grief. I missed that.
    Windows 7 Pro x64
    Mid 2010 iMac
    8 gb
    1 TB
    N/A
    2 gb
    1440 x 900
    300 GB
