Help for VSS - HyperV - WindowsBackup, please
T
T.M. Taglicht
I would appreciate some help for an issue with VSS - HyperV - WindowsBackup
(WB).
What happened:
- Had 2 Hyper-v servers w2k8 with several VM's on them, backed-up with
Windows Backup.
- Updated all Hosts and VM's to W2k8-R2.
- On 1 server WB runs fine.
- On 1 server WB does not backup the volume containing the VM's, only if
they are stopped, even so, in the Hyper-v console, the VSS shadow copies
succedes.
- The error is that the writer (hyper-v) cannot create the shadow copies.
"The backup operation that started at '‎2009‎-‎08‎-‎24T10:01:21.706000000Z'
has failed because the Volume Shadow Copy Service operation to create a
shadow copy of the volumes being backed up failed with following error code
'2155348129'. Please review the event details for a solution, and then rerun
the backup operation once the issue is resolved." (there is no more
detail.....)
What I did:
- Recreated all VM's by using the existing VHD's only.
- Resinstalled Hyper-v
- Tried to remove all shadow copies: "C:\>vssadmin delete shadows /All".
Got :
"vssadmin 1.1 - Volume Shadow Copy Service administrative command-line tool
(C) Copyright 2001-2005 Microsoft Corp.
Error: Snapshots were found, but they were outside of your allowed context.
Try removing them with the backup application which created them."
I'm stucked here....
I do not know how to use WBadmin to remove the shadows nor if I'm on a good
path to troubleshoot this.
Thanks in advance.
TMT.
T
T.M. Taglicht
I try to make it shorter...
On windows server 2008-r2,
Windows Backup DO backup the volume on which are Hyper-v VM's, if they are
STOPPED.
Windows Backup DO NOT backup the volume on which are Hyper-v VM's, if they
are RUNNING (1 or more).
Thanks,
Thomas.
"T.M. Taglicht" <thomas.taglicht@newsgroup> wrote in message
news:uyifJeWJKHA.2516@newsgroup
> Hi,
> WindowsBackup
> (WB).
> What happened:
> Windows Backup.
> succedes.
> code
> rerun
> detail.....)
> What I did:
> Got :
> tool
> context.
> good
> Thanks in advance.
> TMT.
M
Meinolf Weber [MVP-DS]
Hello T.M. Taglicht,
For Hyper-V i suggest you use either:
http://social.technet.microsoft.com/Forums/en/winserverhyperv/threads
http://social.technet.microsoft.com/Forums/en/windowsserver2008r2virtualization/threads
Best regards
Meinolf Weber
Disclaimer: This posting is provided "AS IS" with no warranties, and confers
no rights.
** Please do NOT email, only reply to Newsgroups
** HELP us help YOU!!! http://www.blakjak.demon.co.uk/mul_crss.htm
> Hi,
> WindowsBackup (WB).
> What happened:
> Windows Backup.
> if
> copies
> succedes.
> copies.
> '?2009?-?08?-?24T10:01:21.706000000Z'
> a
> code
> rerun
> detail.....)
> What I did:
> /All".
> Got :
> tool
> context. Try removing them with the backup application which created
> them."
> good
> Thanks in advance.
> TMT.
