Help! I Can´t be longer than 30 minutes on my computer!
J
Jeffrey v.a.
I am dutch so my englishe is not very good.
Since i have Windows Vista my pc stops after 30 minutes. (sometimes shorter
and sometimes any longer.)
When i am surfing 30 minutes on internet my mouse don't move anymore and i
can't do anything, so i must put my computer off.
And when i'm playing a game i have this problem after 10 or 15 minutes.
And when i'm not on my computer but he's only downloading he's do it for a
couple of hours.
It's very weird but it's true.
When i had Windows XP i never had this problem.
Please! Can someone help me?
Cause i love Windows Vista and i never wan't XP anymore!!
Thanks!
R
Rick Rogers
Hi Jeffrey,
Open the event viewer and check the system and application logs for clues.
Does the system freeze? Or just shut down? Is there an error message?
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
"Jeffrey v.a." <Jeffrey v.a.@discussions.microsoft.com> wrote in message
news:A53D4B95-730A-49A5-BFC9-23B9DD4CD98E@microsoft.com...
> Hi,
> shorter
> couple of hours.
> Thanks!
K
KilrPilr
Re: Help! I Can´t be longer than 30 minutes on my computer!
Blow the dust bunnies off of your cpu heatsink and power supply. Your
machine is probably overheating. If its clean inside, run the task manager
and check to see if svchost.exe is eating up your cpu cycles.
> Hi,
> shorter
> couple of hours.
> Thanks!
S
Steve
I opened task manager on my system and found 7 instances of svchost.exe
running at the same time. Why? and how do I stop that from happening?
"KilrPilr" <commodore128@removehotmail.com> wrote in message
news:j9yXh.125019$aG1.9620@pd7urf3no...
>> Hi,
>> shorter
>> i
>> a
>> couple of hours.
>> Thanks!
S
Steve
Check that. I just opened it again and found 16 instances of svchost.exe
running.
"Steve" <jedi105@optonline.net> wrote in message
news:OnLQin5hHHA.3472@TK2MSFTNGP04.phx.gbl...
>> manager and check to see if svchost.exe is eating up your cpu cycles.
>>> Hi,
>>> shorter
>>> i
>>> a
>>> couple of hours.
>>> Thanks!
J
Julian
news:edaDWp5hHHA.588@TK2MSFTNGP06.phx.gbl...
> running.
http://windowshelp.microsoft.com/Windows/en-US/help/057580a1-7002-4f43-9240-a74f42cb05c91033.mspx#EV
K
KilrPilr
Hmmm Ive never seen that many instances. Anyways what u are looking for is
one in particular that is using up 90-100% of your cpu. Kill that process if
possible or just go to start/control panel/system and click on the automatic
updates tab and turn off automatic updates. There is a bug or "feature" in
auto updates that is causing cpu's to max and computers to slow to a
unbareable crawl.Let me know if this works for you please.
> running.
>>>> Hi,
>>>> shorter
>>>> and i
>>>> for a
>>>> couple of hours.
>>>> Thanks!
R
#8
Why do you want to stop them? That's normal to have multiple instances
running On this system there are 12 instances running. Each instance is a
container for other services. From Task Manager on the process tab near the
bottom left put a check mark in "Show processes for all users". Highlight
an instance of svchost.exe, right click and click on "Go to services". It
will switch tabs and highlight all the services that are running under that
instance of svchost.exe. Check them out to see what is there. They should
all just be windows services.
Rock [MS-MVP User/Shell]
15
#9
My computer has 19 instances of these what is the idea of these do I need so many??
    AMD Athlon 62x2 Dual Core Processor 3800+ 2.01 GHz
    3GB
    I just want to uprade to Home premium.
M
Malke
#10
> need so many??
Unfortunately, no one can help you because we don't know what "instance of
these" means. See below for why and how to better get help from these
newsgroups.
You are not posting on a real forum as you think you are and you didn't
quote any of the thread to which you are replying. You are using a web
interface that leeches Usenet posts and most of the rest of us are using
real newsreaders. We don't see what you do. If you want to participate in
Usenet, the better way is to set up a newsreader. This is very easy to do
and I'll give you information about that below. If you prefer to use a
forum, then here are two excellent ones:
http://forum.aumha.org/index.php
http://http://computerhaven.info/
Since you are using a web interface, you may not realize that this is really
a newsgroup. You will get far more out of this resource if you learn to use
a newsreader. There are many good newsreaders for Windows, but you can use
Outlook Express (XP) or Windows Mail (Vista) since you already have it.
Here are some links to information about newsgroups:
About Usenet:
http://en.wikipedia.org/wiki/Usenet
http://www.faqs.org/faqs/ - Usenet FAQs from the Internet FAQ Archives
http://www.usenetmonster.com/infocenter/
http://www.elephantboycomputers.com/page2.html#Usenet - a brief explanation
of newsgroups
Outlook Express/Windows Mail as Newsreader:
http://michaelstevenstech.com/outlookexpressnewreader.htm
http://rickrogers.org/setupoe.htm
http://vistasupport.mvps.org/accessing_newsgrousp_with-windows_mail.htm
How to Post:
http://support.microsoft.com/default.aspx/kb/555375 - How to Ask a Question
http://users.tpg.com.au/bzyhjr/liszt.htm - How Not to Get Technical Help on
Usenet
http://www.catb.org/~esr/faqs/smart-questions.html
http://aumha.org/nntp.htm - list of MS newsgroups
microsoft.public.test.here - MS group to test if your newsreader is working
properly
http://www3.telus.net/dandemar/munad.htm - how to munge email address
http://en.wikipedia.org/wiki/Crossposting - crossposting
http://www.blakjak.demon.co.uk/mul_crss.htm - multiposting
Other Newsreaders for Windows:
http://www.forteinc.com/main/homepage.php - Forte
http://www.mozilla.org - Thunderbird
Malke
MS-MVP
Elephant Boy Computers - Don't Panic!
http://www.elephantboycomputers.com/#FAQ
